03-18-2019 05:55
03-18-2019 05:55
In last 6 weeks my intake calories was Under budget and calories out was above the target. I have lost weight but 500-700 grams per week , not 1kg as FitBit is suggesting. I have been over achiever in all Fitbit aspects as water, workout, calories, steps but not the weight!
03-18-2019 06:23
03-18-2019 06:23
Congrats for the great start with your weight loss! Looks like the Fitbit Food Plan is working well for you, i.e. you were able to create the caloric deficit needed for the weight loss to occur. That the actual weight loss is a bit smaller than predicted is no big deal IMO: 0.5-0.7 kg per week is still a very respectable rate at which to lose weight. You have now basically "calibrated" your Fitbit, having found it likely overestimate calories burned, and by how much. If you really want to lose 1 kg per week, you’ll have to create a calculated deficit higher than the one you have had so far. OTOH, I would say you’d be better off losing at "only" 0-5-0.7 kg per week.
Dominique | Finland
03-18-2019 06:17
03-18-2019 06:17
It’s not a perfect science. Fitbit doesn’t know how much lean body mass you have which can affect how many calories you burn. It’s just an estimate. If you are looking to burn 1kg per week than you need to drop calories a little more.
03-18-2019 06:23
03-18-2019 06:23
Dominique | Finland
