03-29-2015 08:13
03-29-2015 08:13
I know this topic is discussed frequently on this board. And there's a lot of science behind both. I thought this lecture was enlightening, and it will help explain why those of us who are on a low-carb diet do so well. If you're open minded you will appreciate the topic. (Oh and the first 7 minutes are kind of non-related so I would skip those)
04-04-2015 16:30
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              04-04-2015 16:30
 Thank you very much for the video @Knowledge! It has definitely given me a lot to think about
 Best Answer04-05-2015 06:18
04-05-2015 06:18
High Fat, low Complex Carbohydrate diets are dangerous to your physical and cardiovascular health.
High Fat, high Protein diets (such as Atkins) can cause rapid weight loss, but also health problems.
High Complex Carbohydrate, moderate Protein, low Fat nutrition will provide optimum health, and this
has been proved in numerous scientific studies. It's also the optimum nutrition for aerobic athletes.
One effective nutritional program is the Pritikin Diet. See the "Pritikin Promise" (cheap on Amazon).
No, there will be no further discussion with the fans (short for "fanatics") of various fad diets.
http://www.quackwatch.com/search/webglimpse.cgi?ID=1&query=atkins+diet
http://www.quackwatch.com/search/webglimpse.cgi?ID=1&query=diets
 Best Answer04-05-2015 07:02
04-05-2015 07:02
@yarddog wrote:High Fat, low Complex Carbohydrate diets are dangerous to your physical and cardiovascular health.
Have you actually watched the video? It is a lecture given by a Doctor in Sports Medicine and in it he explains how for athletes a low-carb diet is advantageous to a low-fat diet (outside of weight loss purposes). Here we go again with you spewing these myths...
Quackwatch.com is not a reputable site so if you coud please stop citing it as your "source"
04-05-2015 08:01 - edited 04-05-2015 08:04
Some more facts about Atkins:
http://www.diseaseproof.com/archives/diet-myths-examining-dr-atkins-deathupdated.html
 Best Answer04-05-2015 08:10
04-05-2015 08:10
04-05-2015 08:11
04-05-2015 08:25
04-05-2015 08:25
@Knowledge wrote:
Please see: http://archive.sph.harvard.edu/press-releases/2006-releases/press11082006.html
Stated in the provided link:
“This study doesn’t mean that you should load your plate with steak and bacon,” said Hu. “One likely explanation that we did not see increased risk of CHD with low-carbohydrate diets is that the adverse effects of animal products might be counterbalanced by reducing refined carbohydrates.
 Best Answer04-05-2015 08:41
04-05-2015 08:41
So, your height, is what? weight a year ago and now, is what?, your blood pressure reading, is what?
Just wondering how this carnivorous obsession is going for you.
 Best Answer04-05-2015 09:11
04-05-2015 09:11
 Best Answer04-05-2015 09:58
04-05-2015 09:58
 Best Answer04-05-2015 10:17
04-05-2015 10:17
@Knowledge wrote:
Agreed and plus bacon has nitrates which Dr Atkins has said are best to avoid but ok in moderation. I eat mostly fish but do eat occasional red meat and of course poultry.
I have been doing low carb since beginning of January and in the 12 weeks I have lost 15% body fat and 58 lbs. Started at 306 lbs with 45% BF and am now 248 lbs with 30% BF. I am 5' 10" and my blood pressure was 119 over 75 and now hovers at 108 over 68 (I was never hypertensive to begin with).
My recent lipid panel from a few weeks ago:
BEFORE:
Triglycerides: 123
HDL: 36
LDL: 143
After:
Triglycerides: 79
HDL: 68
LDL: 88
So, one thing we should get straight, is that when you say "low carb.", there are different kinds of
"carbs.". There are simple carbs. (like refined sugar) and complex carbs (like unrefined grains and
vegetables and fruit). The simple carbs. and animal fats, are like drugs and the complex carbs. with
a minimal amount of animal source protein, is what's needed for maximum human nutrition/health.
At 5'-10" a normal weight would be somewhere around 168 lb. to 180 lb. The weight loss of about
4.8 lb./wk. is excessive, and should be done under a doctor's supervision, and blood pressure is on
the low side, but that's up to you and your doctor. It's the long term that can cause health problems.
High cholesterol (bad kind, by whatever technique), is a concern with high animal protein and fat.
At 6'-0" my weight was once 240 lb., and over the course of 3 yrs. it ranges between 160 lb. and
172 lb., depending on how intensive the athletic training is. With a high complex carbohydrate diet
and a small amount of animal protien, the change was from obese to competively athletic, and the
performance of 5km. and 10km. running races at (predominantly) 1st., 2nd. or 3rd. place finish.
What you appear to be doing (nutrition wise) is certainly your prerogative.
Let's end it there ...
 Best Answer04-05-2015 10:23
04-05-2015 10:23
Agreed. But the term "low-carb" is wide ranging so its not fair for you to criticize a low-carb diet based on the notion of complex vs simple carbs. Many of us eat complex carbs on a low carb diet (fruits, veggies, and unrefined grains). Even Atkins allows these complex carbs (which is a more restrictive low-carb diet). In fact even 150 grams of carbs a day is considered low-carb for many. But at the end of the day the reason complex carbs are good for you is because of the fiber. This is why fruit is good but fruit juice is bad. When you take the fiber out of the equation your insulin spikes and wreaks havoc on your metabolism. I think you have a perception that low-carb is just red-meat and cheese and nothing else, and while that is true for some people, the vast majority of low-carbers I would say eat complex carbs in moderation.
04-05-2015 10:30 - edited 04-05-2015 10:31
Also as for height and weight that is BMI. While good indicator for some it isn't for others that strength train. My LBM is roughly 171 lbs. So at 180 I would be roughly 5% BF and I would be dead at 168 lbs. My target weight is around 193 lbs with a BF of 10% as I think that is a healthy range. Obviously I am dieting but I am changing my lifestyle as well, no more added sugar and refined carbs is my life-long goal and hope to not gain my weight back. Also my weight loss has been under supervision of my doctor and he is completely fine with it as I am not doing anything extreme (eating until full, working out 45 minutes 3-5x a week). Each body is different and since I am not losing muscle mass my doctor says to proceed with what I've been doing.
Congrats on your success. I think we should spend less time arguing and more time focused on the positives. Obviously excess of anything is bad, but I don't think its fair to assume low-carb means only red-meat and nothing else. We all know excess red-meat has been linked with a lot of diseases.
04-06-2015 20:22
04-06-2015 20:22
Great lecture! Thank you Knowledge. Until recently I was pretty biased against low carb diets, but the more I learn, the more I understand the merits of it.
 Best Answer04-07-2015 05:18
04-07-2015 05:18
@_daniel_ wrote:Great lecture! Thank you Knowledge. Until recently I was pretty biased against low carb diets, but the more I learn, the more I understand the merits of it.
You should remain biased against it, as it has few merits. It is characterized by initial rapid weight loss
and then weight stabilization at a level well above where it should be. @Knowledge has provided himself
as an example of this. There are also serious physical problems that may also result. Ask your doctor.
 Best Answer04-07-2015 05:27
04-07-2015 05:27
 Best Answer04-07-2015 05:36
04-07-2015 05:36
@Knowledge wrote:
I haven't stabilized my weight. Since my last post I have dropped 2.5 more lbs currently at 246.5 for a total of 59.5 lbs lost. Have no idea where you got about weight stabilizing above normal. Many body builders successfully maintain their body fat at 6-7% with a lowcarb diet. In fact it tends to be the diet of choice for body builders
When I was younger, I was a serious bodybuilder, and was eating mostly complex carbohydrates.
I'm well aware of the mistaken notion some bodybuilders have about this. You eat what you want.
 Best Answer04-07-2015 05:45
04-07-2015 05:45
04-07-2015 05:49
04-07-2015 05:49
