As a FYI since I find this unbelievable. If you plan on setting your own "manual calorie goal" be aware that it can not be removed or deleted in the future, ONLY EDITED. I finds this ridiculous Fitbit and the support team is not useful in this scenario either.
Best AnswerAssuming you are talking about calories burned, setting your own goal makes no difference here. You are given a default goal for calories burned, as well as for steps, distance, active zone minutes, and I believe floors.
Are you singling out only calories goal that you want to be able to eliminate?
Best AnswerSure you can remove it from view so as not to see it.
But it is a field either default set like many of the goals are, or allows manual setting.
But it wasn't going to be removable or deletable in default setting either, only hidden.
Ever tried to delete your step goal?
Same thing.
If not useful to you - hide it.
But there isn't a problem with it, except misunderstanding what it's purpose it perhaps.
