02-03-2014 15:30
02-03-2014 15:30
Can I input number calories I want to eat versus what it sets when I choose intensity. I don't want to eat 1100 calories. That is crazy. I did have it set at 1300 calories but now its changed.
Best Answer02-03-2014 16:30
02-03-2014 16:30
@dmantok wrote:Can I input number calories I want to eat versus what it sets when I choose intensity. I don't want to eat 1100 calories. That is crazy. I did have it set at 1300 calories but now its changed.
Yes, from your Dashboard find the "Calories In vs Out" tile and hover your mouse over it, a gear icon will appear in the bottom left, click on that. Then click on the pencil next to your Plan level. Hit next (past the weight screen) then on the Food Plan screen click the link at the bottom "Set my own calorie target"
02-03-2014 16:30
Best Answer02-08-2014 16:40
02-08-2014 16:40
Thanks for info: have also adjusted daily calorie target figure.
But, with UK/EU food categories and calorific assessments being at variance to the US-based FitBit ones, how can I input my daily calorie data based on another program & database (Perfect Diet Tracker)?
Best Answer01-05-2015 09:49
01-05-2015 09:49
Best Answer01-08-2015 18:32
01-08-2015 18:32
@citygirl6 wrote:
My calorie target is was way too high (I would have had to up intake by 600+ calories) so I reset it. Unfortunately that disables the calorie balance tracking. Is there any way to have a realistic calorie allowance without losing the calorie tracking?
Why do you think it's unrealistic?
You merely need to eat less than you burn.
By a reasonable amount is more sustainable now and in to maintenance than an extreme amount.
If you think bigger is better - why not just stop eating and get it over with quickly?
Best Answer04-27-2016 10:41
04-27-2016 10:41
Best Answer04-28-2016 08:12
04-28-2016 08:12
@HumingBird65 wrote:
I am unable to find a gear when hovering over the Cal I /Out. It moves the line up.
When hovering over this tile with your mouse for about a second (not clicking, just hovering), additional options should appear at the bottom of the tile.
