12-09-2014 20:43
12-09-2014 20:43
Best Answer12-09-2014 21:59 - edited 12-09-2014 22:00
@Hawkersgirl wrote:
Fb is not logging my food correctly.
You'll have to expound on that if you want any actual help.
So what you said literally means:
You enter in food items (directly in FB or other site that syncs over) with certain calorie levels, and what is shown after doing that doesn't match.
And from your topic title, I'm guessing what you look at is higher in calories than what you just logged.
So based on what you briefly wrote - is that correct?
If so, that's a bug and should be on the discussion categories regarding the site, not weight loss.
And be specific with info, like is this logged through the iPhone app, or the website viewed on the iPhone browser.
What are the exact steps to see the error?
When you open topic in proper category anyway.
12-10-2014 08:42
12-10-2014 08:42
Best Answer12-10-2014 15:06
12-10-2014 15:06
I had logging similar logging errors entering meals on myfitness pal - they transferred to fitbit and showed double and sometimes triple entries. Going to the log on my computer I was able to delete the duplicates OK. I think what happened in my case is that MFP tried and failed to register that data was transferred. With iphone it may be a similar thing. If it persists, try re-installing the app~I had to do that when the mobile fitbit app stopped showing steps~
12-11-2014 00:31
12-11-2014 00:31
Yep, uninstall app and install again. App error.
App talks to app server, app server talks to account.
Once account is updated with info, it's sent back down the line.
It would be interesting if the website account shows same issue after it shows on phone.
Or is it one of those display is wrong, but math is right elsewhere?
And indeed, at least the MFP issue lets you delete the bogus meals, and if you don't edit a meal anyway - no issue it seems.
