After batteling thyroid cancer last year and beating it..
I am now trying to lose the weight that I have gained due to not having a thyroid...
And I am finding it very hard... I see a nutrionist and she has told me that I need to
eat 1,500 calories a day .. Has anyone had a hard time losing weight???
Best AnswerYes I have been counting calories and exercising and I actually managed to gain weight 😞
It is not as easy as the endos and other ppl think 😞
first please accept my sincere woot woot on beating cancer- awesome. second, I don't know that you need motivation, I think you have that, I think you need a more defined plan than 1500 calories a day- which to me sounds really high for losing weight. But I am not a nutritionist so what do I know...
I think the calorie intake, your TDEE, your level of fitness and calorie expenditure should all be evaluated so you know how much to eat, how much cardio, what ratio you need of protein, carb, etc. I just think you need more...my opinion of course..
Elena | Pennsylvania
Best AnswerCongratulations to you both on beating cancer. My sister had throat cancer a couple of years ago and beat it as well. She gained weight and had a hard time loosing it but within time eating healthy and working out she slowly started seeing results. Don’t give up!!!! J
I'm in the same boat as you. I had my thyroid out in 1993, and since then have dealt with thyroid cancer 3X. My endo doesn't believe that weight loss struggles have anything to do with thryoid issues- um, what?!! Those of us who have thyroid issues know otherwise.
Since my total thryoidectomy, I have struggled like mad to get the weight to stay off. What works in my experience is to go low carb. I lost 25 lbs last year following a low carb diet- essentially cutting out all white products (breads, pastas, sugar!!!) and it came off with relative ease (though slow and steady) along with moderate exercise. I don't say "no carb" bc your body needs carbs for optimal functioning. It's low carbs- and the right carbs. But don't get me wrong, even after being diligent as all get out, I felt like my body wanted to hold onto the weight like a life preserver. It was (and is) a struggle. I don't necessarily count calories, but focus more on what types of food I'm eating. I'm hoping by using Fitbit and getting motivated through activity, I will once again be motivated to go low carb and see changes in my body.
Best wishes to you!!
Best Answer"...was not eating enough and my body was going into starvation mode. "
There is no such thing, until you're literally starving (skin and bones). Starvation mode, as presented, is a myth. That being said, crash dieting is no fun and 1500 is likely an acceptable start point.
Best Answerdifferent people call it different names
it isn't what is it called, it is what it does/is that matters, long term calorie deficiency, survival mode, adaptive resonse, starvation response, what ever
at first your body makes you hungry to try and make you eat more
then slows down your BMR, thus reducing the amount of calories you need to consume to survive
continue and you start to lose muscle mass thus reducing your bmr
but people still eat the same amount of calories even though their bmr has dropped
which then means they have over eaten thus gain weight
using myself as an example, before I was 236lbs, now I am 211, if I ate now the amount of calories I ate before I would gain back the weight, thus the yoyo cycle
straight from the article
But, there is something else that needs to be mentioned here which happens to be very real. It’s something better described as the “starvation response.”
Basically, if you do things to your body that it doesn’t like, it’s going to respond in whatever way makes the most sense to it from a survival standpoint.
In this case, the thing your body doesn’t like is an extreme and prolonged deficit caused by either severe caloric restriction (you know, VERY low calorie diets), excessive amounts of exercise (often tons and tons and TONS of cardio on a daily/almost daily basis), or some combination of the two (very few calories coming in with very high calories going out).
In this sort of extreme scenario, your body’s adaptive response is to make it harder for you to allow this to continue and, you know, prevent you from dying.
take today for example, due to being busy, all I have eaten is weetabix and skimmed milk this morning around 9pm, approx 270 calories, and it is now 4pm, and my stomach is grumbling like mad.... time for some grub
however, I will agree though, a good read
Best AnswerSomething Real: The Starvation Response
It slows down your metabolic rate, aka the adaptive thermogenesis I mentioned earlier.
It reduces the amount of non-exercise activity thermogenesis (NEAT) taking place, which in turn causes you to naturally burn less calories.
It causes intense hunger and food cravings, which causes you to eat more than you’re attempting to.
Best AnswerThanks!!
Best AnswerCongrats on beating cancer, My best friend of 43 years also beat Thyroid Cancer about 7 years ago and i'm so proud of her but she too is having a really tough time. Between menopause and no thyroid, it's such a struggle for her but she's not giving up. She knows she is doing all she can and that's all you can do. Try not to be too hard on yourself.
I'm having a hard time myself. I'm 49 and just at the begnning of peri-menopause. I've been on the Fitbit program for 2 weeks. I've kept my calorie intake to an average of 500 calories under budget but this week i haven't load anything. Very frustrating and this is usually the time when i give up, but not this time. I need to know for myself that i didn't give up on me and that keeps me going.
