02-19-2015 16:29
02-19-2015 16:29
Hey everyone,
So I just started working out and eating healthy early 2015. At first I lost about 16 pounds but now all the sudden Im stuck at this number. I cant break it no matter how healthy or well I exercise. Im starting to lose motivation because nothings working. Wondering if anyone had advice they could share with me.
Thanks in advance!
Best Answer02-19-2015 16:38
02-19-2015 16:38
Could you share a bit more? Age? Weight? Height? How many calories you are eating? Exercise?
Best Answer02-19-2015 16:40
02-19-2015 16:40
The best Diet and Exercise program ever, is The Pritikin Promise, available at:
http://www.amazon.ca/The-Pritikin-Promise-Longer-Healthier/dp/0671494473
They also have an interesting and very useful website at:
Best Answer02-19-2015 16:41
02-19-2015 16:41
Im 19 weigh about 194 and im 5'5. My goal weight right now is really 175 but the more the better. I eat salads often and also some fruits and veggies, although I usually have grilled chicken for dinner. Also I go running and do situps, crunches, push ups and other various things.
Best Answer02-19-2015 16:49
02-19-2015 16:49
Sounds like you are off to a good start! Are you tracking calories at all? Programs like MyFitnessPal or LoseIt are a great way to track what you consume.
Also make sure you are eating enough. Look into eating based on your BMR http://www.younglifenorthdekalb.com/fitness/bmr_meal_calculator.php
Best Answer02-19-2015 17:06
02-19-2015 17:06
@mayzing wrote:Im 19 weigh about 194 and im 5'5. My goal weight right now is really 175 but the more the better. I eat salads often and also some fruits and veggies, although I usually have grilled chicken for dinner. Also I go running and do situps, crunches, push ups and other various things.
Following the advice in the above mentioned book allowed me to go from 260 lbs. to 160 lbs.
The formula (for females) for athletic weight for aerobic athletes is:
(3.5 times height in inches) less 108
If you are female, at 65 inches, your athletic weight for aerobic athletes is 119.5 lbs.
One can add 10% to 20% to that (131.45 lbs. to 143.4 lbs.) if not an aerobic athlete.
Best Answer02-19-2015 22:32
02-19-2015 22:32
Merely eating less than you burn will cause weight loss.
Diet is for weight loss, if done right just fat loss, if done wrong includes muscle mass loss.
Exercise is for body improvements - done right supports fat loss, done wrong helps muscle loss. Most improvements are actually weight gain, not loss.
The only thing exercise does for weight loss is make you burn more daily, so that when you eat less, you hopefully can still sustain it.
It too little though - say goodbye to muscle and freak your body out and stress it and have a fight on your hands.
Based on several references to eating healthy/better and what you are eating, I'm betting you think less eating the better. Very untrue. Reasonable deficit is best, don't freak the body out.
With only 20-25 lbs to lose, you should hopefully be doing 1 lb weekly until to 10 lbs left, and then 1/2 lb weekly.
Let Fitbit tell you how much you burn (though you need to manually correct the calesthentics workouts because Fitbit is way too low on calorie burn there), then with your weight loss plan set to 500 cal deficit, eat the goal given daily.
A goal is something to hit too, not miss. You willing to miss goal weight by 20% and say that's close enough? Then don't miss your eating goal by 20%. 50 over is better than 100 below.
Keep those restistance training exercises, only thing that will tell your body to keep muscle.
And probably more protein, 145 grams daily is good goal while in weight loss mode.
