Not loosing weight
Three weeks ago I was a couch potato. I got my fitbit and have worked my tail off. Everyday I get a "nailed it" on my calories. I have done my 10,000 steps and get the band buzz. I drink over the amount of water needed and workout 50 minutes a night on my elliptical and exercise bike. I am also getting an average of 7-8 hours sleep. On my tracker everything is green. I work out at night before I go to bed so of course my calories I can take in goes up but I don't use them. With all this I am still not loosing weight. I need to loose about 45 pounds.
What do I need to do to get the weight off? I am getting discouraged but not giving up:)
32 REPLIES 32
Is cardio all you are doing? If you are working out at home, add some body weight exercises. Examples, push ups, sit ups, jumping jacks, burbees. You can do a HIIT/Tabata type program at home. With the cardio, up your intensity and resisitance. You can interval train, 1 minute really fast, 30 sec slower, 1 minute really fast, etc.
What you get by achieving your goals is not as important as what you become by achieving your goals.
You did not mention for calorie intake.  Myfitnesspal works with fitbit....and is a great food diary...where most items are on their data base.  I started using a scale too....so I was not being over eating and under counting the calories taken in.
Go to fitbit discussion of myfitnesspal users...There is one woman that really knows her stuff and helps alot in the community forum.
Good luck!
Deb from Midwest
I work out at home and do 30 on my exercise bike and 20-30 on the elliptical. I just started doing the Slim 6 Six pack abs last week three times a week. What is a hiit/tabata? Would I do that on top of what I am already doing?
I take in exactly the amount the fitbit tells me. When I first started I would be about 200 under and was told I needed to get within 20 of the amount that is my goal which right now it tells me 2184 a day. I am burning on an average 2639 a day.
Good job on reaching your goal for eating.
You wouldn't purposely miss your goal weight would you.
Are you accurately logging food though. Even though the Fitbit is slightly underestimating daily burn, especially if you don't manually log non-step based workouts like elliptical and bike it is bad on, you could wipe that out with some bad logging.
Or depending on how intense that is, your daily burn could be a whole lot more than 2600.
Calories is per weight, not volume.
You weigh yourself - do you weigh the food that goes in you, for accurate logging?
Help the next searcher of answers, mark a reply as Solved if it was, or a thumbs up if it was a good idea too.
Thanks for taking the time to help me.
I get a lot of my steps when I do my workout so I get my steps and I log the activity. I usually have about 7000 steps before I start my workout. I changed my workout yesterday that is aerobic with weight training.
As far as food, I don't weigh anything,I just log it. I do make sure my food has low fat and high protein.
Sent from my iPhone
Then you really don't know how much you are eating.
Until you weigh the food, even packaged, don't expect any results.
And since you must eat less than you burn to actually lose weight - you can't accomplish that.
Well.......it has only been 3 weeks. Your body is adjusting and could be hording some fat. Keep away from processed foods for awhile if you are eating them. Eat whole foods, lots of green veggies and fruits mostly all sorts of berries. Nuts are good too, but just one handful as they are dense with calories. Stay away from bread but if you like pasta, switch to a brown rice pasta, they are just as good as wheat but bettter for you. lean protiens such as fish and chicken. Beef, maybe once or twice a month, use it as a reward. but mainly, keep on keeping on. The weight did not come overnight and it will not leave you that fast either. Have fun with it too! ~Steve~
dacamesare,
i think im in the same boat 😕 my first week using flex i lost 3p now its week 2 and i seem to be holding (didnt lose this week or gain). I generally get 7000-14000 steps a day depening.My workout is 30 low impact aerobics - its depressing to hop on that scale thinking you've done great to see the same numbers 😞
I also agree with Steven since its still so new to us our bodys might be unsure if it should drop those pounds or not.Have you tried changing your meal plan? i just did mine today and am hoping since i choose slightly harder i'll see a difference in numbers next week.Losing weight sucks but remember to stick with it and im sure you'll see results soon 🙂
Stick with it means not changing things around until there has been sufficient time.
1 week is not.
Because weight loss is NOT linear - you will not lose the same amount weekly.
There are all kinds of valid reasons for water weight gain.
Besides the fact, women's BMR actually changes through the month - that will NOT be reflected by Fitbit.
So you need at minimum a month to see a direction and results from any changes.
To Heybales point, there have been stretches where I haven't gained nor lost weight for 3 weeks, then suddenly drop 3 lbs over the next two weeks...  in a couple of cases, even though my deficit would "yield" a pound or two drop over a period, I gained a little weight then again later, suddenly it drops off.  Your body tries to maintain homeostasis (a balance)... and sometimes that means holding onto or letting go.  Your body knows what it's doing, and we don't always understand everything that's going on in our bodies.
I've been wearing my fitbit since the end of February and I've lose 33 pounds.  Still have a long way to go.  I haven't lost anything in the last two weeks.  I've increased my exercise and even cut back on my calories and nothing.  HELP!
HI,
I have been in pretty much the same boat. Three weeks ago, I decided I needed to change my habits and my life. I got started on the Fitbit app without the wristband, and after a week weighing my food, and tracking everything myself, I had already lost a kilogram. I purchased the wristband, and find it inspires me to get out and be active every single day!
This last week, I have not lost any weight at all even though I have dramatically increased my output of calories. I know it is hard to remain focussed when the scale tells you something other than what you think it should, but you need to give your body time to adjust and realise that this is a long term change and not just another fad you are trying. Once the old metabolism really fires up, that's when you will start to notice more on the scale. Don't forget also that exercise builds muscle, and muscle weighs more than fat, so in theory you should gain weight before you can lose it. Building muscle also forces the metabolism to work harder to feed those muscles - so if you are consuming less than you burn, guess where the muscle gets its "food"? that's right - your fat stores are there for this purpose.
It' easy to get dispondant, but you need to keep the longer term, bigger picture in mind to enact sustained change. I'm proud of myself, and I'm proud of all the people on this forum for being so committed to themselves and to each other. Don't give up - we will all get there Woman Very Happy
My two cents... I was on a similar state when I started making changes in my life three months ago. I noticed that once I started exersicing and keeping track of In vs. Out regarding calories, I lost 15 lbs from 4/28 to 7/18. I started at 256 and I am at 241. However, my "beer gut" was still somewhat there, although sagging a little bit.Since I was doing cardio and wieght training I started to tone just a bit, however I hit a rut. I was not burning fat and by the time my next workout came (every other day) my muscles had "deflated" and did not see any tangible changes. Untill I learned about our metabolism. As it turns out, our body was designed to burn fat. However, due to the culture we live in, all we eat is process foods and refined sugars. Thus our bodies have adjusted to burn sugar instead of fat. And as we continue to eat "healthy" we provide our body with more sugars in the form of carbs. Since our body is used to burn sugar at this point, it will utilize anything it can find to turn int into sugar for fuel. Thus the carbs that you eat, will be turn into sugar for fuel and the rest into fat to "save for later". The problem is that, again, due to the food we eat, we continue to provide our body with sugar and we never let it access the fat stores for fuel to revert the process. What I have learned is that we need to reverse this vicious cycle. And the only way to do this is to re-train our bodies to be the fat burning machines that they are by minimizing or eliminating our sugar/carb comsuption. I could not believe it myself either, fatty foods do not make you fat! I couldn't belive it!!! As long as you excersice and re-train your body to burn fat, you can eat that burger pattie with cheese and still burn fat as you sleep. Amazing!. Notice that I left the bread bun out of that statement??. Please, do not take my word for it. I advise you to check www.mercola.com. All of the details and  scientific research is there. This is not a new fad, nor a diet. Is a lifestyle change for your own good. Since I started with some adjustments in my diet after reading the information on that website, I can already tell/feel that I am burning fat. And that was just last week! I have not wighted myself again, as I have a habit of doing once a week, but the way I feel tells me that I am in the right track. Time will tell.
Wrong combo direction.
So your body is under stress with less eating than normal and much more activity than normal - and you increased both stresses.
Stress will cause body to adapt in ways you don't want and won't help, and it causes water retention too.
Stay at a reasonable deficit off what you burn daily. Like 500 or 1 lb weekly if you have 10 - 25 lbs to lose.
Actually, the body will respond to a major change long term by adapting, but not the way you are describing, it'll slow down if too extreme.
There isn't any firing up of the old metabolism, you are likely just burning more daily than you used to - that's not metabolism.
Progressive overload builds muscle, not just any exercise. And you can NOT gain weight and it be muscle eating in a deficit. Water retained for various reasons sure - muscle - not a chance.
Your muscle also doesn't get more from fat stores, which are useless except as energy source, which is was doing anyway.
Sounds like you think the metabolism is more than it really is, and some big misconceptions about what the body is doing. But you aren't alone - those myths float all over as good advice.
"not losing weight, must be gaining muscle" - people aren't aware how slow that process is, and what must be done to accomplish it. Nice thought, fails later though.
Hey, he made the list of biggest quacks, alright.
http://www.alternet.org/print/personal-health/four-biggest-quacks-plaguing-america-their-bad-claims-...
Our body at lower levels of intensity is indeed designed to burn fat - and guess what it still does up until you can't take in enough oxygen to support that oxidation? Burn fat, with carbs being mixed in more and more as intensity increases and enough available oxygen goes down.
You sitting there reading the screen possibly upset with my response are burning almost total fat for the muscle and most organs, except brain using blood sugar for power.
Start shaking your fist at the screen vigorously and perhaps a few more carbs there are used.
Your diet isn't changing those facts unless you've just eaten.
In which case what you just ate is used as energy source, and carbs refills liver and muscle stores, and when that is done (and in a diet it's done before they are filled) your blood sugar drops and fat burning is back to normal, except earlier than otherwise while in a diet. Hence increased fat burn in a diet.
But that is ALL carbs - you just eat fruit and vegetables and that doesn't change, it's all glucose once digested anyway with same response.
And guess what else kicks off the insulin response to cause the above effects - protein!
You eat a straight protein and fat meal and the same insulin will go up - unused protein will be converted to glucose, and now the same process is happening. And indeed, you can eat too much protein, and after topping off glycogen stores once converted, that glucose will be converted to fat. Again, in actual diet eating less than you burn that won't happen.
And your exercise isn't going to retrain your body what to burn as fuel. Your level of intensity will determine that. And you getting fitter will allow more fat to be burned at higher intensity levels.
But that's true no matter what the diet is.
That guy really is a quack with his take on human physiology that goes against all studies of human metabolism and fuel oxidation.
If you just massively dropped your carb intake, you just massively dropped your glycogen stores in muscles, along with attached water. That's the same big weight loss everyone gets starting a diet, just bigger with less carbs.
And as soon as you eat more carbs, or more food in general and more protein is converted to carbs, that fast water weight will come right back.
As heybales said, don't overdo it and burn yourself out! The closer you get to your goal, the slower it comes off. Also, weight loss isn't linear... You can lose 3 lbs in one week, then nothing for the next three weeks, then lose again. Just stay at a calorie deficit and keep your head up. These are the moments when people who don't succeed give up! Can I add another cliche? Oh, okay, slow and steady wins the race 🙂
Have a cheat meal. Sometimes doing that will fire up the metabolisim and begin to burn more. You have to change something because your body has adjusted to your routine. With workingout, do a different routine each time. If your running, do rowing or bike instead. If you are just walking, run. Change it up, you will start seeing results soon. good luck, and most importantly, have fun!!
