09-18-2019 19:05
09-18-2019 19:05
I know this topic has been covered bunch of times but for some reason I'm still confused..
I am female, 38 years old , 5'10, 196lbs. I'm down 70 lbs and haven't been able to lose weight for awhile now.
I've used online calculators to calculate my calorie need and it goes from 1400-2800. I use alta Fitbit. I average 11000 steps a day and eat average 1700 calories . I use beachbody app and have been doing insanity max 30 . I do modified exercises and usually do 2, 30 minute programs 5-6 days a week...plus about an hour of jogging on a treadmill. I try to do liift4 occasionally. I have a desk job but I do exercise about 2hrs+ 5-6 days a week.
Am I just simply eating too many calories? Thanks for your help and support in advance
Best Answer09-18-2019 22:39
09-18-2019 22:39
@Katc81 wrote:I'm down 70 lbs
I think this is the key to what you’re seeing: you have lost a lot of weight (26% of your starting weight), perhaps in a relatively short period of time (though you didn’t mention that). As a result, your body’s built-in survival mechanisms have kicked him to prevent (what it considers to be) further damage. What is going on is well explained in the Losing All Your Weight At Once video by Dr. Mike Israetel, one of my favorite weight loss resources. Your goal for now should be maintenance, not further weight loss, so you can rebuilt your metabolism and be in a better position to go for the next round of weight loss, later on.
Dominique | Finland
09-18-2019 22:39
Dominique | Finland
Best Answer09-20-2019 21:37
09-20-2019 21:37
Let me preface this by saying that I'm just a chubby shmuck. This is just my two cents... I was in a similar situation. I've recently lost almost 35 pounds. The first 25 came off easily, but then I hit a plateau. I've been using the same calorie counting app, and I love it. So I thought the answer was to just push myself harder. I was hitting the gym pretty hard about 4 days to 5 days a week for at least an hour at a time, and sometimes up to two hours. But the scale didn't budge. So I decided to back off a bit and just refocus on nutrition. And funny enough, the weight started coming back off. All that to say- you might be overdoing it with the exercise. Maybe try backing it down a notch and instead focus not just on your calories, but what you're actually eating as well. Nutrition really seems to be the key, at least for me. But regardless of what happens, it sounds like you've already done an amazing job! 97 pounds is no small feat!!
09-26-2019 05:02
09-26-2019 05:02
Hello! I know you marked this as solved but I just had a question. You said you are doing Beachbody, do you have that Beachbody coach that is working with you and supporting you?
09-26-2019 08:03
09-26-2019 08:03
Hi,
Best Answer09-26-2019 12:54
09-26-2019 12:54
