@Leescat - Fitbit will take your calorie burn into account when it's giving you a budget. If you've set your deficit to 1000 then try and end your day in the zone (neither under or over). If you are going to bed a couple of hours before midnight you may end up a little under, but I wouldn't worry about that. As with any diet the calories in is a guess (even with a good tool) so keep doing what you're doing and in a few weeks you can adjust.
Also, I'm in the 'need to lose a lot' group so I'm not as good with advice for people who may only have a small amount of weight to lose. However, 1000 calorie deficit may be too agressive if you don't have a lot of weight to lose. I understand that those with less to lose may do better with a smaller deficit.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
@Leescat wrote:
I have been using the fitbit and logging my food for about 2weeks now. I am trying to loose weight and have my goals set at the 1000 calorie deficit. What do the under budget over budget calories in and calories out mean? If I choose the 1000 calorie deficit does that mean I have to burrn 1000 calories more than I eat and always end my day under budget? So far I am under budget for about 6/7days of full tracking.
I don't see any movement on the scale, but it is early yet so I will just keep at this pace and hope I'm doing everything right.
If you have a 1000 calorie deficiet, and you eat 2,000 calories in a day and burn 3,500 calories in that day, you are "under budget" -> you could have eaten more. Your total calorie deficiet was 1,500
If you have a 1,000 calorie deficiet and you eat 1,500 calories and burn 2,500 calories, you are "in the zone" with a 1,000 calorie deficiet.
If you have a 1,000 calorie deficiet, and you eat 1,500 calories, and you burn 2,000 calories, you are "over budget" because you ate more calories than a 1,000 deficiet from what you burned.
Collin | Los Angeles, California
One, Charge HR, Aria - Android 5 (Moto X), Mac
Take a look at the Fitbit help site for further assistance and information. Help others while waiting for help!
