Has anyone been successful in getting a Fitbit Charge 2 to 'speak' to the Lose It app? I would appreciate any advice on the subject- frustrating and annoying having to enter food on two platforms and then having to enter the steps from Fitbit onto the app
Best AnswerI'm obviously an impatient person.... Afterbout two hours, the apps are speaking to each other. Thank you xx
You can link them through the app gallery which is here
https://www.fitbit.com/partnership
Wendy | CA | Moto G6 Android
Best AnswerThank you, I have at least my calories on Lose it from the Fitbit, but no food info from Lose it on the Fitbit. It's a start though. Thank you again 😀
Maybe there is somethign you need to do with Lose it as well. I dont use it so cant help. But check over there.
Best AnswerWhy should it take that long to update the Fitbit app with data from Lose-it? Both apps are on my device, after all, and I updated Lose-it first, before syncing. It does update eventually as noted, but shouldn't it be a lot quicker? (Lose-it Free and Fitbit Charge HR on Galaxy S8 Nougat but also on earlier devices)
Elaine
