12-30-2016 16:29
12-30-2016 16:29
Has anyone been successful in getting a Fitbit Charge 2 to 'speak' to the Lose It app? I would appreciate any advice on the subject- frustrating and annoying having to enter food on two platforms and then having to enter the steps from Fitbit onto the app
12-31-2016 07:18
12-31-2016 07:18
I'm obviously an impatient person.... Afterbout two hours, the apps are speaking to each other. Thank you xx
12-30-2016 23:46
12-30-2016 23:46
You can link them through the app gallery which is here
https://www.fitbit.com/partnership
Wendy | CA | Moto G6 Android
12-31-2016 05:45
12-31-2016 05:45
Thank you, I have at least my calories on Lose it from the Fitbit, but no food info from Lose it on the Fitbit. It's a start though. Thank you again 😀
12-31-2016 06:44
12-31-2016 06:44
Maybe there is somethign you need to do with Lose it as well. I dont use it so cant help. But check over there.
12-31-2016 07:18
12-31-2016 07:18
06-12-2017 02:28
06-12-2017 02:28
Why should it take that long to update the Fitbit app with data from Lose-it? Both apps are on my device, after all, and I updated Lose-it first, before syncing. It does update eventually as noted, but shouldn't it be a lot quicker? (Lose-it Free and Fitbit Charge HR on Galaxy S8 Nougat but also on earlier devices)
Elaine
