08-12-2014 08:15
08-12-2014 08:15
I periodically add my current weight [at least once a week, sometimes more often] and use whole numbers since my scale doesn't give me decimal points [though quite some time ago, I may have listed my weight with a .5 added to the weight if the needle on the scale was in between the 2 numbers. But I haven't done that in quite some time.
So how come it tells me that I've gained or lost a certain amount that includes numbers with decimal points, like a 0.9 or 0.3 or whatever?
Just wondering...
08-12-2014 08:48
08-12-2014 08:48
Do you use metric units (kg), by any chance? If so, Fitbit converts everything to imperial units (lbs) internally, then back to metric. This could explain why you're getting decimals.
Dominique | Finland
