05-10-2016 17:57 - edited 05-10-2016 19:33
Is it good if I have more of a deficit in calories each day? I'm burning almost half of what I eat. My settings are set for me to lose 2 pounds a week, requiring me to have a 1000 calorie deficit. But I'm always under that too. Should I lose more pounds this way?
Best Answer05-11-2016 00:03
05-11-2016 00:03
Whatever you do must be sustainable over time. I see from your profile you have just started with Fitbit:
Why don’t you do what you are doing (exercising and eating) for a couple of weeks and see how things go: do you lose the expected weight, is hunger manageable? Remember that what you actually burn isn’t necessarily what your Fitbit tells you, and what you actually eat isn’t necessarily what you counted. There’s a margin of error in both.
Dominique | Finland
05-10-2016 17:58 - edited 05-10-2016 19:34
Best Answer05-10-2016 20:34 - edited 05-10-2016 20:35
it is completely fine to not eat all of the calories allotted you each day, that way if fitbit miscounted then you have buffer.
05-11-2016 00:03
05-11-2016 00:03
Dominique | Finland
05-11-2016 01:46
05-11-2016 01:46
to lose weight you need to be in a calorie deficit, however, if you feel hungry, try drinking some water first, as it might just be thirst, however, if it continues, then eat something, doesn't have to be a huge meal
continuously staying hungry is not good for you
for example, my daily calorie allowance is around 1600, and I eat that much, fitbit gives me x amount of calories, usually around 1500 or so, but I don't eat them, as after around 1600 or so by the end of the day, I am still full
if however I feel hungry, then I go and have a snack, something like a Special K bar or 2, small bowl of cerial or something like that, nothing worse that having a large snack just before going to bed, as when you sleep, your body metabolism slows down
somedays I do eat more, like when we have a family meal at a restaurant, I can't ask the waiters/watresses what the calories are for everything etc, so I take those days as a treat, but I do eat in moderation and not stuff my face in, as that was what got me in trouble in the first place 😄 also eat slowly to allow your stomach to tell your body is full
when you go out shopping, take a look at the calories etc, eventually you will start to remember the amount of calories that they have, so when you go out, you can roughly guess how much calories the dishes have, obviously it won't be perfect, due to flavouring, kind of oil used etc, but you can at least have a rough estimate
also look the food up in myfitnesspal, it has a large database of food, I won't say they are all correct, but it will give you a rough estimate
05-11-2016 12:22
05-11-2016 12:22
i just eat until i am full\at the calorie limit.
