07-07-2020 02:16
07-07-2020 02:16
Hello
my app is not allowing me to change my weight loss start date and not showing how much weight I have lost in total?? Have tried so many different things and can not find the answer. The start date auto populates and I cannot seen to edit this. Can anyone help? Thanks.
Best Answer07-07-2020 07:33
07-07-2020 07:33
Hi @SunsetRunner
On the Fitbit App - go down to the weight loss section, tap on it. There should be a settings icon in the upper right hand corner (middle icon on the right hand side). There you can change the items by tapping on the particular item. For example, you can tap on the start date and change the date and then tap ok.
I hope this helps 😊
