07-27-2019 07:47
07-27-2019 07:47
Hello fellow fitbit users.
I have been using a fitbit since they first came on the market. I have recommitted myself to walking daily, lifting weights and logging my food. I have a goal of losing weight. Does anyone understand how setting a goal of losing weight and using the food log and calorie counter works? Is the number of calories left set to allow me to lose weight or maintain my current weight? I am not sure if I should try to be under the number of calories left by say 500 calories to ensure weight loss.
Does anyone know if I work to zero out my calories left but not exceed, will I lose weight? Does anyone know what rate the goal is set to lose weight?
Any feedback would be appreciated.
Best Answer07-27-2019 09:46
07-27-2019 09:46
All calorie counting tools (including Fitbit) rely on the idea that you need a cumulated deficit of 3500 calories in order to lose one pound of body weight. That’s a average daily deficit of 500 calories.
When you create a food plan geared at losing weight in Fitbit, it will let you choose between four "intensities": 1) Easier, 2) Medium, 3) Kinda hard, 4) Harder. They correspond to daily deficits of 250, 500, 750 and 1000 calories, respectively. Based on your current weight and your target weight, Fitbit will tell you the estimated date when you should reach your target weight.
Have you created yourself a food plan and chosen an intensity for it? If so, have you got specific questions about that plan?
What you should keep in mind is that calories burned reported by Fitbit are an estimate, and the intake logged by you is also an estimate. For instance, Fitbit may say you burned 2000 calories and you counted your intake as 1500 calories (in which case you would have a estimated deficit of 500 calories), whereas in reality, you only burned 1800 calories and you actually ate 1700 calories (in which case your real deficit would only be 100 calories).
Dominique | Finland
07-27-2019 09:46
07-27-2019 09:46
Dominique | Finland
07-27-2019 13:35
07-27-2019 13:35
Best Answer07-28-2019 07:52
07-28-2019 07:52
I remember setting up the intensities on my iphone fitbit app. But now I can't find that page. Can you tell me how to navigate to it? Or even to find it on the website page?
Best Answer07-28-2019 08:12
07-28-2019 08:12
@Mitytlyk : you need to edit your food plan at https://www.fitbit.com/foods/log
It’s under "Plan Summary":
Dominique | Finland
Best Answer07-28-2019 16:04
07-28-2019 16:04
Best Answer07-31-2019 08:33
07-31-2019 08:33
Thank you for your helpful information - much appreciated!
