12-21-2014 22:23
12-21-2014 22:23
I was recently on the Weight Watchers website. I was debating giving that a go because it syncs with your fitbit. Does anyone here do that? let me know how well it works
12-22-2014 13:38
12-22-2014 13:38
I have it and I really like it. Ive used WW before and I never counted my activities because I didnt want to give myself too much or too little so I never bothered. But with the fitbit linked to it my activity points are automatically updated 🙂
12-22-2014 13:38
12-22-2014 13:38
12-22-2014 13:40 - edited 12-22-2014 13:40
It really depends on the person. I think it gave me to many AP's so I unlinked it.
I go by My Heart rate Moniotr instead
But a lot of people like it
Wendy | CA | Moto G6 Android
12-22-2014 14:49
12-22-2014 14:49
I love Weight Watchers but there are some problems with Weight Watchers syncing with Fitbit and other activity devices. I reset my profile so I add my steps by hand rather than syncing. It just was not working.
12-22-2014 17:40
12-22-2014 17:40
Thank you 🙂
Because of you, WW has gained another member! It worked quite well for me last time.
12-24-2014 07:32
12-24-2014 07:32
BTW if you need a new WW buddy, feel free to add me up. CashiusClay
12-25-2014 04:27
12-25-2014 04:27
Hi! I'm also a fitbit and WW person. The syncing problem between the two is quite annoying. I've taken to entering my steps manually. Otherwise I'm very happy with the combination. I'm motivated and slowly but steadily losing. I have the same user name on WW and would like to connect there with others who have a similar approach to losing weight.
12-26-2014 07:51
12-26-2014 07:51
I have used the WW activelink and have now switched to the Charge - very happy with the change. Yes all fitbits sync with WW. You will love it!
12-27-2014 21:04
12-27-2014 21:04
My WW username is Kimbiz623, find me. I was using the Activelink but Santa got me the Charge and Aria.
12-30-2014 17:59
12-30-2014 17:59
01-06-2015 06:39
01-06-2015 06:39
I am having trouble getting my WW and Fitbit to sync. I have also been having some issues with logging into WW since they started all of this privacy stuff. Does anyone have a solution to the issue?
01-06-2015 07:46
01-06-2015 07:46
Hi Everyone,
I've been a WW member for a while. I use the tools online and go to meetings. I just got my fitbit on Sunday. I have been able to sync it to WW and have been log in to WW. I only 'hooked' it up last night though so not sure if it working properly.
I've gotten motivated to do better on my weight loss journey and have my entire family eat healthier and getting more active. I'm looking for people to share ideas with. My outdoor exercise this is limited in the cold weather this week. Hopefully it will be a bit warmer in the evening next week.
Hope to get to know of you better.
02-28-2015 08:14
02-28-2015 08:14
it is so discouraging that the weight watchers and fitbit connection does not always work...but it happens far too frequently and for no apparent reason.
03-14-2015 11:54
03-14-2015 11:54
Hi everyone, I got my Fitbit Flex today having joined WW last week. Any words of wisdom or encouragement would be appreciated. On to lose 3st! Got to get active and usually cheat so need to be kept ont he straight and narrow! Had a Fitbit Charge for Christmas but had trouble with the strap so have been without it for a month - today I got the flex....
01-06-2016 10:56
01-06-2016 10:56
Hi
I've just started having problems with the WW app syncing with my fitbit, it's been working fine since November then it stopped working on Saturday. I removed everything and added it again and it worked for the rest of Saturday and Sunday but it hasn't worked since so I've been adding the steps manually but I'd like to get it sorted if anyone has any ideas? I'm pretty sure it's not the fitbit that's the problem.
01-06-2016 13:33
01-06-2016 13:33
The Problem is with WW site. I dont know why they cant get it sorted out.
I started linking again and then gave up. It's just easier to add them.
01-23-2016 20:43
01-23-2016 20:43
