Solved!
Weight Watchers and new to fitbit
1 ACCEPTED SOLUTION
11 REPLIES 11
Solved!
Very good questions, I hope you get an answer. I synced w...
Solution
Hi...I am also on WW. I would say that tracking on the WW...
Thanks for your help !
How do I sync my FB to my WW account?
You do it from your weight watchers account. Go to your a...
Thanks Sent from my Verizon Wireless 4G LTE smartphone
Ella- have you noticed that when you ride the fitbit coun...
I would use the Weight Watchers etools and use that to lo...
Go to the WW watchers etools and then under SEARCH put in...
Re: Weight Watchers and new to fitbit
