06-23-2016 19:44
06-23-2016 19:44
I havee seen alot of messages and forums about the "--" under the lbs lost since and I figured out what my issue was.
1. Enter a starting weight under the Account Settings, Nutrition and Body section.
2. If you enter lose weight, during entering your goal, and you actually gain weight it will show as "--"
3. If you click on Maintain, then enter the weight you want to maintain, it will show you lbs from goal.
Just a few tips that may be helpful for people using the app.
Best Answer07-05-2016 07:21
07-20-2016 13:39
07-20-2016 13:39
Thank you this was very informative or helpful!!!! ![]()
