Anyone else had an issue with the weight loss goal not moving regardless of losing weight? I’ve lost a few lbs. but it still shows none (on what I call the rainbow). I reset the goal today but that may not help.
You need to set your goal at your final goal. Otherwise you will be missing badges along the way
Wendy | CA | Moto G6 Android
I set my on my fit bit at 50 lb increments, if I couldn't realistically hit that number in two or three months I would shorten it to 20 or so but so far I am hitting mine in 2-3 months. I know that at some point I will drop it down to 20-30 once I get closer to my goal.
Best AnswerGood luck with your goal! I just had to delete the old goal and replace with a new one for it to finally track correctly. Unfortunately that meant previous progress would only be shown on my weight log/graph.
Best AnswerI set mine at my final goal, which unfortunately won't allow alot of movement on the graph (as well as badges earned) for myself personally, since I didn't purchase my fitbit til I only had 29.6 pounds left to lose to hit my final weight goal, but just as important as getting those weight goal changes, and badges, is the ability to better maintain the weight once it's lost through having the device. Ultimately maintaining the weight once it's gone, is far more important than the computerized rewards ya get to keep ya motivated by earning those badges for goals reached..........Good Luck to you!!!!
@DanieJo wrote:Mine is not tracking when I lose weight either. Any help?
Are you logging your weight on Fitbit?
