09-05-2019 16:19
09-05-2019 16:19
Is it possible to see your weight loss % on Fitbit app?
Best Answer09-06-2019 14:00
09-06-2019 14:00
Hi, @Ladydeech, that is, unfortunately, not among the statistics instantly available, though it is, of course, fairly easy to work out: just take your weight loss, divide it by your starting weight, and multiply by 100 and you will get the percent loss.
For example, if you weighed 150, and you lost 15 lbs you would say 15/150 = .1 x 100 = 10. So you have lost 10% of your weight.
If you wouod like to see this as a quick statistic on your app, why not make a features suggestion? You can do that in the Feature suggestion forum. There others can comment on, and vote for your suggestion. Your idea is just a little bit of maths, so would be easy to implement, but Fitbit would want to be sure that people wanted this, as it would take up space in the app.
