12-15-2013 12:42
12-15-2013 12:42
I've lost 18lbs since october and could do with some incentive to keep going. I still have another 59lbs to lose!!!! How much weight do you have to lose before you get a badge??
12-15-2013 12:45
12-15-2013 12:45
Do you use an Aria scale?
I believe that ALL badges, including weight, are only granted from data collected by a device and not by manually recorded activities or weights. That goes for steps, floors, distance, and weight too.
So to get weight badges, I believe you have to be using a scale that will pass the data itself.
12-15-2013 12:53
12-15-2013 12:53
so unless I use the Aria scale I will never get any weight loss badges?? That's rubbish!!! Come on fitbit!! sort it out!! That's unfair!!
12-15-2013 13:20
12-15-2013 13:20
Or a withings scale.
And its not rubbish. How can they verify a manual enty?
Wendy | CA | Moto G6 Android
12-15-2013 13:31
12-15-2013 13:31
I would expect fitbit to trust people to enter their correct weight. After all, it's yourself that will suffer if you fabricate your weight loss. Also, fitbit can't verify what we've eaten when we enter it, nor can they verify our activity completely as you could easily give the tracker to someone else to wear or add additional exercise that you haven't done....and if you wanted to you could get someone else to stand on the fitbit aria and record their weight!! So really, I dont see why we can't be trusted to enter our own weight to earn badges.
12-15-2013 14:29
12-15-2013 14:29
Don't shoot the messenger. I was just trying to answer the original question. I don't think it is a matter of Fitbit needing to "sort this out" -- I am pretty sure the decision was very intentional on their part. So regardless of whether or not you or I agree, I was just trying to help you understand why you have not seen a weight loss badge.
12-15-2013 15:11
12-15-2013 15:11
Personally, I don't care so much about weight badges. Plus, do you lose a badge if you gain a couple of pounds? I'm down anywhere from 15-20 pounds depending on the day, but I don't want to get "punished" by losing a badge every time I eat too much salt one day and then weigh more the next morning! 🙂
Keep giving me those step/floor/mile badges, though!
12-15-2013 15:19
12-15-2013 15:19
12-15-2013 15:35
12-15-2013 15:35
Give yourself some credit for how much you've lost--I think the first few pounds are among the hardest because it doesn't happen without a LOT of changes made at once.
12-15-2013 17:02
12-15-2013 17:02
Hey! I herby award you a Verbal Badge!! Good job. I haven't lost any weight yet but I'm hoping. Good luck to you!!!
12-15-2013 18:13
12-15-2013 18:13
If you can get it, I would recoment getting an Aria (you do need to have access to WiFi). Had mine about a year. My standard process is, is that when I'm staking a shower, I turn ofn the water and while it's getting hot, I step on the scale.
The problem with manual entry can be this:
I had my yearly physical in Oct. I knew my current weight, but at the doc's wanted to see how close my scale was (and at that point I was fully dressed!) There was a 3 lb difference - clothes, I'm sure.
When I got the report of the physical, the person manually entering the numbers had transposed the last two digits, giving me a weight 20+ lbs heavier than my actual weight. As a result, the BMI in the report was also off, etc. I've been trying to get this corrected for over 2 months now, as this was in my actual physical! And I even dropped off a copy of my Fitbit (Aria) weight data.
12-16-2013 01:34
12-16-2013 01:34
Best Answer12-22-2013 12:28
12-22-2013 12:28
try something like this to motivate you http://www.pinterest.com/search/pins/?q=weight%20loss%20jar
Best Answer12-23-2013 11:25
12-23-2013 11:25
I'm with you on this. I love getting the badges! It's encouraging to me.
12-23-2013 12:01
12-23-2013 12:01
I agree with you EdinburgLass. If people cheat it is their ownselves they are hurting! Why should the rest of us, who are honest, have to buy more products to qualify for encouragement? I paid 100 dollars for this fitbit, isnt' that enough? I am sure most of us already have scales and shoudn't have to buy a special data synching scale.
12-23-2013 12:29
12-23-2013 12:29
12-23-2013 21:53
12-23-2013 21:53
A wee bit off the topic, but where do you live now Edinburghlass? I'm originally from Falkirk, but live in Utah, USA right now.
I think (hope hope hope) I'm getting an aria scale for my Christmas, as like you, I find the badges motivating. I agree with whoever said it before... I give you a verbal badge for your acheivements so far ![]()
Cheers,
Donna aka BearsBairn
Best Answer12-24-2013 01:07
12-24-2013 01:07
Best Answer05-11-2014 10:32
05-11-2014 10:32
...and the flip side is that when you lose weight you lose the badgering of those around you! Your secret badge.
