01-16-2014 13:28
01-16-2014 13:28
What does "ST" mean under weight
Best Answer01-16-2014 13:46
01-16-2014 13:46
Do you mean St as in Stones?
Best Answer01-17-2014 07:22
01-17-2014 07:22
it means stones. 1 stone = 14 lbs.
01-17-2014 11:20
01-17-2014 11:20
It could refer to Strength Training.
Best Answer12-27-2016 10:51
12-27-2016 10:51
Yes, ST mean stones but I think the real question is how do you change it.
If you go to Advanced Settings you can change the unit. I had to change my weight to lbs and the length to miles but I guess it depends on where you are from.
I hope this helps!
11-07-2020 18:57
11-07-2020 18:57
Thank you so much!! This is exactly what I was looking for 😊
