01-16-2015 12:20
01-16-2015 12:20
using the ariba scales, last weigh in was 212.8 and todays was 211.5. When I went to school, that equals a 1.5 lb loss, but the website says its only 0.6! How our education system has failed us!
Best Answer01-16-2015 12:23
01-16-2015 12:23
When I went to school that was a 1.3 pound loss. LOL
Best Answer01-16-2015 12:29
01-16-2015 12:29
Check to see where the "starting date" is set for that particular stat.
Best Answer01-16-2015 18:45
01-16-2015 18:45
The math for recording weight loss is not calculated correctly, can this be fixed and/or can you over ride it?
Thanks...so frustrating.
Best Answer01-16-2015 22:50
01-16-2015 22:50
@divedragon wrote:using the ariba scales, last weigh in was 212.8 and todays was 211.5. When I went to school, that equals a 1.5 lb loss, but the website says its only 0.6! How our education system has failed us!
So where exactly on the website does it show weight lost since last weigh-in?
Rather than weight lost since starting weight?
Because if your starting weight was 212.1 - guess what is correct?
Best Answer01-16-2015 22:51
01-16-2015 22:51
@RedRoe wrote:The math for recording weight loss is not calculated correctly, can this be fixed and/or can you over ride it?
Share the math you think is incorrectly calculated, in case it could be the same reason as first post.
Best Answer01-17-2015 04:49
01-17-2015 04:49
Best Answer01-17-2015 22:17
01-17-2015 22:17
@RedRoe wrote:
January 9 starting weight was 145 lbs.
January 16 weight was 143 lbs - a loss of 2 lbs.
Fitbit says a weight change of 0.7 lbs.
Then suggestion above applies, you need to check the past dated entries and confirm dates and weights.
If correct, then contact support about it to have your stats reset.
Best Answer01-18-2015 00:49
01-18-2015 00:49
Best Answer01-18-2015 00:50
01-18-2015 00:50
Best Answer01-19-2015 20:14 - edited 01-19-2015 20:15
Hi @divedragon
Can you please provide me with more info about the miscalculation you're seeing?
I checked your profile and it is showing the correct number in terms of change from your starting weight of 225. Can you please specify where you're seeing the miscalculation?
Looking forward to hearing back. Thanks!
Best Answer01-19-2015 20:26
01-19-2015 20:26
Hi @RedRoe
I'm sorry to hear that you're seeing a miscalculation. I checked your dashboard > weight log for those specific days and I am seeing 2lbs as the difference.
Can you please provide me more information as to where you're seeing the miscalculation? Are you using a mobile device to view? What browser are you using? Are you using a custom view, week, month or year view?
Look forward to hearing from you! Thanks!
Best Answer01-20-2015 07:40
01-20-2015 07:40
That is it...thanks!
