01-06-2018 13:02
01-06-2018 13:02
I use to see my weight tracked since I started using a fitbit, but now they only show data for the past year. Did fitbit really just destroy all my data?
11-24-2024 15:18 - edited 11-24-2024 16:50
It only showed the average from 2020 unlike before it showed everything. I had history info before since 2012
It is now showing only from Jan 4, 2018. After Uninstalling and Installing Fitbit, the oldest date got worst, only showing from Feb 6, 2023. I'm using Android version 14
11-24-2024 15:34
11-24-2024 15:34
Mine is now showing since 2020 only and just the average. I used to see similar to the one you have in your post
11-25-2024 05:34
11-25-2024 05:34
Thanks Julia_G! I see the all time, but all my data isn't there. It is more than 10 years, so maybe I got caught by a purge.
11-25-2024 11:37
11-25-2024 11:37
Hello @Worldtraveler65 , @FannySantos , @Moosegirl
This is a known issue for Android phone users after the recent app update. See this thread (<-- click link).
One of the Moderators has acknowledged the issue and will posting updates on this thread. You might want to join/follow that thread so you'll see the updates.
Best Answer02-17-2025 14:02
02-17-2025 14:02
My historic weight data seems to have gone too. I've been using FitBit since 2015 but I can only go back in time with weight to January 2023. My historic mileage and activity is there but the weight data is gone. The weight data is one of the main reasons I've stayed with FitBit over the years. Seems to have broken since Google bought FitBit. Please help!!
04-03-2025 16:02
04-03-2025 16:02
On another thread I found trendweight.com which displays all my fitbit history (from the past 12 years) nicely. Better than the old web dashboard. It appears all the data is still there which is a relief.
