02-01-2016 22:41
02-01-2016 22:41
Best Answer02-02-2016 05:00
02-02-2016 05:00
There is a setting for whether you are wearing it on your dominant hand or not. I think nondominant probably is better, only because you will probably get fewer "false" steps that way. But make sure your setting agrees with the wrist you are using. Go to the gear symbol in the upper right of the dashboard, choose "settings" and then "device". You have to scroll down a little to see it.
Best Answer02-02-2016 06:12
02-02-2016 06:12
Best Answer02-02-2016 07:23
02-02-2016 07:23
Actually I found it more accurate when I changed the setting. I wear it on my Dominate arm but the setting is set to Non-Dominate. Works better for many people
Wendy | CA | Moto G6 Android
02-02-2016 08:37
02-02-2016 08:37
Best Answer02-02-2016 08:40
02-02-2016 08:40
Its been a long time since I changed and I really dont remember if the Calorie burn was different.
It was just more accurate with steps
02-02-2016 08:46
02-02-2016 08:46
Best Answer02-03-2016 09:05
02-03-2016 09:05
I've mostly worn it on the dominant wrist, but non-dominant more as I'm right handed and using that hand if I'm going back and forth with my arm aggressively it triggers steps. Like petting your dog and belly rubs counts as 100 steps.
Best Answer02-04-2016 12:53
02-04-2016 12:53
