03-08-2016 12:26
03-08-2016 12:26
03-18-2016 09:46
03-18-2016 09:46
I know from first hand experience that aging does make weight management tougher - I also have thyroid/hosimoto's which cycles through my system putting my metabolism low at points.
If you eat good/clean, exercise to keep the body healthy, get proper rest - then it should be a matter of tweaking your diet a bit or exercise a bit to start to loose some weight.
I'm sure pre-menopause has an impact.....
Track your diet for two weeks, to a very detailed degress and see if there's any indicators there that would be getting in the way. Sometimes its a matter of switching up your exercise also - if you do the same 'things' over a long period of time, your body starts to do them more efficently reducing the calories burned.
03-18-2016 10:11
03-18-2016 10:11
Ah. Sleep. Now there's an issue. I have had chronic sleep disturbances for a couple of years now. I used to sleep 8 hours. I almost always go to bed at 9 (my entire life) but now am waking up at 2, 3, 4am and cannot go back to sleep. On days I get less than 8 hours, I am overall sluggish.
Sorry to hear about your Hashimotos. My mom had hyperthyroidism and I have a sister who has hypothyroidism. So far, knock on wood, no problem there. Hopefully never!
Best Answer03-18-2016 10:18
03-18-2016 10:18
Your lack of sleep could be a big factor - here's an article from WebMD regarding it: http://www.webmd.com/sleep-disorders/excessive-sleepiness-10/lack-of-sleep-weight-gain
Maybe seeing a Dr about it will uncover the root cause and once you start getting enough sleep, your weight loss will happen.
Best of luck!
