06-26-2015 09:13
06-26-2015 09:13
im new to fitbit, and i want to lose weigh, so ive put in that i want to lose 11/2 a week, so its given me the calories i need to eat each day, thing is, it keep adding calories on from my calories burned i think(not clued up with it yet) so my calories keeps going up? how am i going to lost weigh, and how do i take it off and just have the calories i need, i dont want to use my calories ive burned, if that makes sence, it keep confusing me, thank you x
06-26-2015 11:54
06-26-2015 11:54
@SunsetRunner wrote:arrrrrh i undertsan now, why didn't it just say that lol, thank you for replying and the help xx
No problem. If my solution worked, click "accept as solution" to help the next person 🙂
06-26-2015 09:29 - edited 06-26-2015 09:31
@SunsetRunner wrote:im new to fitbit, and i want to lose weigh, so ive put in that i want to lose 11/2 a week, so its given me the calories i need to eat each day, thing is, it keep adding calories on from my calories burned i think(not clued up with it yet) so my calories keeps going up? how am i going to lost weigh, and how do i take it off and just have the calories i need, i dont want to use my calories ive burned, if that makes sence, it keep confusing me, thank you x
In order to lose weight there needs to be a deficit between calories burned and calories consumed. If you want to lose 1.5 lbs a week, you need to eat 750 calories less than you burn. When you excersize, your calories burned increases, therefor the amount of calories you eat will go up. You are still keeping the 750 calorie deficit, even though you eat more some days than others. It all depends on calories burned.
There is a setting to make your calorie goal static. Let's say you want to eat only 1800 calories a day. I believe the only way to do that is to go into your settings on the Mobile app and under Diet, Food you can "set your own goal". Type in 1800 calories and then fitbit will keep track of how close you are to that goal each day, no matter how many calories you burn.
Either way will help you lose weight. Some prefer to keep a static calorie goal while others just want to keep a deficit depending on how much they burn.
Hope this helps! Welcome to the forums!
edit: I stand corrected. You can change your calorie goal on the dashboard. When you go to set your goals, on the second "slide" there is an option at the bottom to "select my own calorie goal".
06-26-2015 10:02
06-26-2015 10:02
06-26-2015 11:54
06-26-2015 11:54
