No. There's no any connection between drinking coffee and loosing weight, for example.
But , lots of fat burners which are used by bodybuilders, people doing fitness or trying to loose weight faster than working out in a gym contain caffeine. Here is one just for example http://drenastim.com/product-information/
Every "body" is different. I enjoy coffee.
Regarding weight loss, the important thing is to minimize calorie intake so a latte' or monster drink isn't a good idea compared to black coffee. Caffeine definitely does not erase calories in 😉 Balance that fact with anything that helps get you up and moving is indeed a help. No magic pill, keep moving, your heart is the most important muscle in your body and you need it, literally, your whole life. Even and steady wins that most important of races.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
@MateoD: here is the hierarchy of the main factors that affect weight loss / body composition:
Caffeine (whether coming from regular coffee or from a "fat burner" supplement) would fit in the last category, the least important. It can have some positive impact: it is a stimulant and may therefore cause you to be move more than you would otherwise; it can also suppress appetite, causing you to eat less than you would otherwise. However, it’s perfectly possible to create the caloric deficit you need without caffeine or any other stimulant / appetite suppressor. Whether or not you decide to take caffeine, you must have the more important factors dialed in first.
Dominique | Finland
Best AnswerNo. There's no any connection between drinking coffee and loosing weight, for example.
Caffeine is a thermogenic, so yes, it can help you lose weight assuming you are doing everything else right.
Best AnswerCaffeine as the part of same drugs and preparats thet help to lose weight , but single using off caffeine don`t help to lose weight . I true anderstand you?
If you take two identical persons who are trying to lose weight, they eat the same, exercise the same etc. and the only difference is one takes caffeine and the other doesn’t, the extra weight loss achieved by the one who takes caffeine will likely be insignificant. In other words, taking caffeine by itself won’t cause any meaningful weight loss. The weight loss will have to come from more important factors (the most important one being an adequate caloric deficit). If you are in a caloric surplus, you can take all the caffeine you want, but you won’t lose weight.
Dominique | Finland
I understand your point of view. Just heard in a television show that caffeine can help in weight loss. It seems to be a myth.
It can help, for the reasons I mentioned earlier (it’s both a stimulant and an appetite suppressor), but the impact will be very limited. It’s not a "magic pill" you can take while sitting on your couch that will trigger a crazy weight loss all by itself. There are no magic pills for weight loss. The main driver of weight loss is a caloric deficit. If you don’t get that right, you can forget about all the rest.
Dominique | Finland
