01-16-2014 11:39
01-16-2014 11:39
If so it is common knowledge over there that you should eat back your exercise calories as that is how that program is designed....is fit bit the same way? Are we supposed to eat back that calories we burn off as well or does fitbit somehow calculate that in and we shoudln't do that?
Best Answer01-16-2014 12:16
01-16-2014 12:16
Yes, the "Fitbit calories left" will factor in your calorie burn, and give you more calories the more you move. It will also take calories away if you are being a slug.
01-16-2014 12:16
01-16-2014 12:16
01-16-2014 13:44
01-16-2014 13:44
There is even a goup for My Fitness Pal and Fitbit users. http://www.fitbit.com/group/229X5C
03-20-2014 15:02
03-20-2014 15:02
I love using MFP, and the FitBit intigrates easily with this program.![]()
Best Answer08-22-2014 00:23
08-22-2014 00:23
I was using MFP before I got my flex and they work great together. I've lost about 12Kg using the pair of them now 🙂
Best Answer02-10-2015 11:21
02-10-2015 11:21
A few days back I linked my Fit Bit to My Fitness Pal, I use to use fat secret, but they do not let you link your FitBit, so I tried this. Thus far I love it! I love how it gives you more calories for moving, so you have more leeway to eat a little more if you choose. Over the weekend, after doing the Weekend Warrior Challenge (38,000 steps in 2 days) and linking my fit bit to my fitness pal, I lost 2lbs. So I am really feeling My FitnessPal. Add ChubbyGirl520 if you are looking to inspire each other : ) Happy Stepp'n!
Best Answer02-10-2015 13:27
02-10-2015 13:27
Hey there @jdj125 ! Welcome to the forums ![]()
The way MFP handles your caloric budget is that upon creating your profile, you create a certain caloric deficit goal (-250 calories, -500 calories, -1000 calories) and this tells you how many calories you are restricting to get an estimated weight loss per week.
This means that your Food Log for the day is already counting your caloric deficit goal, plus your calories given from your Fitbit activity. Your Fitbit tracker will send this information when the accounts are linked and your Fitbit syncs.
Short answer: Yes, you need to eat the calories back, since your budget is already including the deficit you chose. ![]()
Best Answer03-12-2015 12:59
03-12-2015 12:59
Best Answer03-12-2015 21:31
03-12-2015 21:31
@Cuddlestwo wrote:
Recovery runner I'm new to this where should I look where it gives more calories when I move and takes away when I dont. I log my food on mfp only
In your Exercise Diary, under a line called Fitbit calorie adjustment.
You must have negative calories enabled though for it to remove on days you are really sedenatry.
More info.
Best Answer03-12-2015 22:01
03-12-2015 22:01
I think that My Fitness Pal is an amazing site to use when striving towards weightloss. Its so organized and as far as ive observed its the most accurate when searching new foods that dont have a barcode!
Best Answer03-13-2015 04:34
03-13-2015 04:34
