01-14-2014 14:44
01-14-2014 14:44
I drink veggies smoothies/ or juices I can seem how to log in my kale pinapple smoothie. They done fit into the catagores that I see. Any thoughts?
Best Answer01-14-2014 16:57
01-14-2014 16:57
i was thinking about that too. i was thinking if i add the ingredients of my smoothie (i.e., one banana, 1/2c. of strawberries...), that would work. Is that possible for you to do?
Best Answer01-14-2014 23:44
01-14-2014 23:44
Best Answer01-17-2014 04:33
01-17-2014 04:33
I use myfitnesspal for logging foods and what I have found is that you have to log each ingredient seperately. I don't know what you are using but myfitnesspal has a recipe creator and i use that to create the smoothie and log it that way. Otherwise, if you are just using fitbit to log, I would log all your ingredients seperately.
