floors climbed target but no altimeter?
I have a "floors climbed" target on my dashboard which I can't seem to delete. Its in the large panel on the left hand side. It won't let me set the target to zero either so I've set it at 1 floor!. My flex doesn't count floors so how am I meant to achieve the target???!!!! confused!
Maddison
2 REPLIES 2
On the dashboard, you can hover over the tile, then look for a gear-looking thing in the box that will appear near the bottom.  Click on that and it should let you delete the tile.  I deleted mine because it wasn't something I cared about.
On the phone app, you can click Edit on the upper left of the dashboard, then uncheck the circle on the left next to the box that tracks floors.  Then hit Done.  You can also reorder the tiles this way - by doing a drag and drop using the three lines to the right of each bar while on the Edit screen.
ETA: Oh, on the large tile.  Sorry.  As far as I know, you're stuck with it unless you remove the whole tile.
FitBit One
"You should really wear a helmet."
5K 9/2015 - 36:59.57
Thanks for the info, the stars climbed bit is just on the bottom right of a whole tile, and I don’t want to delete the whole tile because I need the other information. Maybe I’ll just have to live with never meeting that target!
Maddison
