03-23-2017 05:26
03-23-2017 05:26
I am trying to get my weight down and I am trying to drink more water and tracking it on my fitbit as well as my food intake and steps. Can anyone tell me the benefits besides hydration?
Best Answer03-23-2017 07:06
03-23-2017 07:06
If you are drinking water instead of say a soda, the first benefit towards weight loss is the calories! I could easily consume two 2 liters of Dr. Pepper a day if I let myself. Just think about all those calories!
Also your body NEEDS water to function. Every single part just about. The cells in your body cannot do their job if they are hydrated. The better your body's organs and systems are working the more efficient your weight loss will be because you are working against less.
03-23-2017 07:09
03-23-2017 07:09
@Bionicwoman71: I heard that drinking water before your meals reduces the appetite, which leads to less consumption of food in turn promotes weight loss. Also drinking too much water is not good for health. Also it should be the combination of diet and exercise. Here are the few links to read more about that.
http://www.webmd.com/diet/news/20040105/drinking-water-may-speed-weight-loss
http://www.medicaldaily.com/7-ways-lose-weight-drinking-more-water-your-diet-247471
Bhuvana
03-23-2017 20:52
03-23-2017 20:52
Water has many benefits. But one thing I know is that when your body is hydrated it is less likely to hold onto water making your weight loss more consistent. If you're not hydrated enough and one day you decide to drink more water than usual, your body will retain that water and it will make it seem like you gain 10lb when it is just water. Then you will be frustrated and probably throw a tantrum that you gain weight out of nowhere then quit or something. good luck.
03-25-2017 15:47
03-25-2017 15:47
@Bhuvana yep drinking a glass of water before eating helps
Best Answer03-31-2017 11:16
03-31-2017 11:16
More than half of your body is water. You need to be hydrated for your body to function efficiently. Things like oxygen and nutrients being delivered throughout your body, etc... Water is used for all functions including digestion, absorption, circulation, saliva, body temperature as well as transportation of nutrients as mentioned before. Now think about what your body is doing when you are eating the right nutrients, exercising, etc... Those functions are what makes use of the nutrients, makes you able to work out and gives you the energy to workout. Without water you are basically doing all the right things in the fast lane, but your highway is jammed up. Water makes what you do to be healthy possible. Basically your body is constantly working for you. Keep it hydrated and it works more efficiently. That is the actual need. For others...
I've read that the right amount of water and potassium helps to counter the stupid amount of sodium that we put in our bodies. It was on the internet so take that with a grain of salt (pun intended)
