08-22-2014 07:40
08-22-2014 07:40
How do i correct my starting weight on my profile?
Best Answer08-22-2014 08:27
08-22-2014 08:27
@judekirby wrote:How do i correct my starting weight on my profile?
@judekirbyClick on the drop down box See more > on your Food Plan then on the LH <. which will show your deficits etc, then click on the Edit Plan, it will turn red and there you have your weights.. Next your way out etc.
Sometimes I find that screen wont move so I adjust my goal weight by the smallest possible amount and then you can advance.
Best Answer08-22-2014 14:07
08-22-2014 14:07
