how to reset weight goal
ANSWERED
how do you reset your weight goal once you have reached your original goal?
1 BEST ANSWER
Accepted Solutions
Just click on the cogwheel of the weight tile (it's located in the lower left corner) in your Dashboard. You will then be able to edit your weight goal, as well as your body fat goal (if you want).
Dominique | Finland
3 REPLIES 3
Dominique | Finland
Thank you.
There's a bug in your software.
I updated my weight goal per these instructions last month.  When I go to Dashboard with my PC, it shows I have 2 more lb to loose, which is correct.  When I go to Dashboard from my tablet (droid), Dashboard says I've achieved my (old) goal.  I have synced many times, sometimes from the PC and sometimes from the tablet.  Both show my current weight, but I can't get the tablet to recognize my new goal.
