07-28-2014 11:53
07-28-2014 11:53
How much weight is considered safe to lose per week?
09-12-2015 23:43
09-12-2015 23:43
@Deeks wrote:I am curious does everyone else's fitbit Charts say there burning a crazy amount of calories? I understand that the ideal deficit is from 500 -1000 cal but my fitbit chart is showing me that I'm burning 4300-5000 a day. It seems like it's way more then I'm actually burning I mean my metabolic rate is around 1800 for 5foot 8inch male 28 years of age. I have a active job and do about 60-90min of workouts a day but still seems to me like 5000 is a lot. I'm eating around 1900-2100 right now and loosing fat but also loosing muscle. Averaging about 3lbs a week and 1lb of that is usually muscle :(. Do any of you think that the calories burned is accurate and I should be upping my cal intake?
That is so totally dependent on the person and their size, and then their level of activity.
Age and height are minor part of it - weight is the major factor for moving calories, and non-moving calories.
Depending on what the active job is - that could be very realistic.
But - couple of things to confirm.
Go look at your daily graph of steps and calorie burn, 5 min blocks. Looking at the lowest block of calorie burn during the night or not moving, that figure / 5 x 1440 = close to Mifflin BMR.
Or should be.
Some have reported that while their weight is displayed visually correct, it seems to be using it as a KG weight, and therefore the calorie burns are based on almost 2 x the real weight.
Also, since calories on moving are ultimately based on steps (and distance from them with mass moved) - look through that daily graph and confirm no big spikes or blocks of steps that just doesn't match up with what you recall going on.
Also, 500 - 1000 deficit is reasonable for fat-only loss if you have 30 - 60 lbs to lose, those being the minimum amounts to use that deficit to encourage fat-only loss.
You may not be aware of how difficult it is to build muscle back - usually is a goal of most to not lose any - if they are aware of the fact you lose it in a diet.
I'm betting you need to up your calories anyway, even if the TDEE is slightly inflated when you check the above things.
09-13-2015 07:28
09-13-2015 07:28
09-13-2015 10:28
09-13-2015 10:28
@Deeks wrote:
From looking at the charts the lowest block number while I'm sleeping is 18cal blocks not 5.also I'm not to sure how to tell if its using kg or lbs as my weight I have the units set for lbs. As for weight lifting I was 191 now am sitting at 169. Which isn't that much weight to be moving around to add up to those calories. Yea i definitly don't want to loose any muscle! How can I correct this issue if my fitbit is saying 18cal blocks when they should be 5?
Ok, so that resting metabolism being based on gender, age, weight, height proves you are getting hit by the bug - the entered weight appears to be pounds but it's actually using KG.
Re-enter your weight and save - that's all. Or change to bogus and then back again.
Then check out the new value.
But - your resting is NOT going to be 5 cal per 5 min, it'll be more than that - mine is 6.75, yours will be about the same. 1800 / 1440 x 5 = 6.25 about per 5 min block.
10-24-2015 06:20
10-24-2015 06:20
Thats how I do, I watch those cabs closely and I don't eat a lot of bread, If I have a sandwhich I eat wheat bread. Works for me.
10-24-2015 14:53
10-24-2015 14:53
10-27-2015 11:37
10-27-2015 11:37
My docs said 1 lb a month that you can keep off is better than 1 or 2 lbs a week.
This comes from my Cardiologist, my Endocrinologist and my regular Dr.
Better yet, forget the scale.
Concentrate on how your clothes fit as Muscle wieghs more than fat
I was 170+lbs and fit into a size 16
I am now 168 lbs and fit into a size 10/12
next goal is to get my waist below 35" which reduces my risk of developing Type 2 diabetes.
10-27-2015 11:46
10-27-2015 11:46
10-31-2015 18:17
10-31-2015 18:17
Nice post Lew, congrats on your weight loss, you certainly seem committed. Hope you enjoy, take care from downunder lol
10-31-2015 18:45
10-31-2015 18:45
11-01-2015 04:40
11-01-2015 04:40
Hey, Larry, great encouragement. I started FitBit to regain my health. I was almost crippled with a back problem, and even after the problem was healed, I was walking bent over and had several areas of almost constant pain. I believe that the human body is able to heal from all maladys as long as you give it the right nourishment and exercize. Reading about ultramarathon runners has convinced me that more exercize is better. However, I do believe you need to give your body time to transition from a couch potato to an ultramarathoner -- time to restore calcium to bones and time to rebuild cartilege in joints. I think of white carbs as inflamatory's, which means they work against my goals, not just as unhealthy calories, but that they hinder the recovery of my joints and aggravate the arthritis. These operating beliefs have helped me lose weight in my first month and a half with fitbit, but also my resting heart rate has dropped 10 beats per minute.
11-01-2015 05:51
11-01-2015 05:51
11-03-2015 12:07
11-03-2015 12:07
Safe - no more than 2 lbs. per week.
11-12-2015 10:34
11-12-2015 10:34
I have used Medifast to lose weight with great success. In the beginning of this plan, you lose sometimes 5+ pounds per week, then it evens out to 2 to 5 depending on exercise, male/female, amount you need to lose, etc. Before the "but I'm a nutritionist, and I think..." purists jump in, let me note that this is a medical program that came about to help pre-op gastric bypass patients safely lose weight. It has been around since the 1980's and has had numerous clinical trials done on it. I think the rule of 1 to 2 pounds per week is a good rule, but I think the Medifast plan can be an acceptable exception to that rule, especially if you have more than 50 pounds to lose since the health implications of being overweight can be significant and losing it as quickly and safely as possible has clear health benefits that may outweigh the potential downfalls.
11-13-2015 06:03
11-13-2015 06:03
When people lose a lots of weight quickly, the next question they have would have …What do I do with my skin?
It is very important that you lose no more than 2 lbs. per 7 days so your whole body could adjust to the changes.
As always – There's more than one way to skin a cat.
11-17-2015 08:03
11-17-2015 08:03
I know a few people who have been successful with Medifast. The ones who have succeeded, also kept up with the maintenance phase. THe ones who went back up in weight, didn't.
Just remember, any of these plans or ways of eating have one thing you must understand. You are not on a diet, you have chosen to change the way you eat for the rest of your life.
Keep up the good work!
11-17-2015 11:38
11-17-2015 11:38
11-28-2015 23:50
11-28-2015 23:50
1% of your cureent weight per week
11-29-2015 07:57
11-29-2015 07:57
acording to my Weight Watchers Leader Joyce it is 1/2 to 1 pound a week.
12-06-2015 06:24
12-06-2015 06:24
For me about a pound a week is average.
12-06-2015 11:28
12-06-2015 11:28
