01-01-2014 09:10
01-01-2014 09:10
I want to start improving my cardio health. Where can I find a good program which I can run myself in my own little gym? Thanks
Best Answer01-03-2014 09:50
01-03-2014 09:50
I also recommend the 5k beginners program. I have the Couch to 5k app on my phone and even if your goal isn't to run a 5k, the workouts are really great, not too long and you build up your strength and stamina in a gradual way.
Walking is also an excellent way to break into cardio. When i first started working out regularly I started with a 30 minute walks on the treadmill. At first I did just a full 30 minutes at one pace, say 3.5. Then i gradually worked up to a brisker pace, 4.0. When I felt better stamina wise I then increased the incline and made sure to pump my arms, went a little longer and now I add in sprint intervals. If you stick to it, you'll make improvements pretty quickly. Once your more confident with doing cardio you can do more challenging workouts.
01-01-2014 11:59
01-01-2014 11:59
How about walking, for a start? I see you've been using your Fitbit for a couple of weeks and are averaging about 4000 steps per day. Use the default goal (10,000 steps per day / 70,000 steps per week) as your first main goal. You don't need to reach it right away if you think your fitness level is not sufficient for the time being. You can set intermediate goals (eg. 40/50/60,000 steps per week) until you reach it. Same with speed: you can start at your own pace and increase it as you get fitter (you can monitor your progress with speed via Very Active Minutes or VAMs).
Dominique | Finland
01-01-2014 15:29
01-01-2014 15:29
Best Answer01-01-2014 17:05
01-01-2014 17:05
01-03-2014 09:50
01-03-2014 11:43
01-03-2014 11:43
great idea, I just signed up to use it on my Samsung Phone.
Best Answer04-04-2015 04:19
04-04-2015 04:19
I do Cardio Drumming 3 times a week . it is a lot of fun and you feel it the next day ..
@jack69 wrote:I want to start improving my cardio health. Where can I find a good program which I can run myself in my own little gym? Thanks
