03-12-2014 13:33
03-12-2014 13:33
im having trouble with my dashboard it dropped my calorie intake from 1200 to 250 can someone tell me how to fix this. must be a glitch
Best Answer03-12-2014 15:33
03-12-2014 15:33
Might be something to do with your meal plan? For example, I tried changing my calorie intake but then it would never stick. I then looked in my meal plan and I had been rather optimistic in choosing the extreme one... I then moved it back to the 'easy' one, which is a realistic option for me at the moment.
Harriet | UK | Don't wish for it work for it!
Flex, Samsung Nexus & Windows 7
Don't forget to mark as a solution or vote for a posting if you find it helpful 🙂
03-12-2014 15:33
Best Answer03-12-2014 17:24
03-12-2014 17:24
Best Answer03-12-2014 20:20
03-12-2014 20:20
On the dashboard - hover curser over food plan tile, on lower part left side a gear icon (setting) will appear, click on this and it will take you where you want to go
Hope this helps
Craig
