04-17-2020 00:57 - last edited on 04-19-2020 15:56 by LiliyaFitbit
Just went to check the period logs and everything before March 21st has disappeared. I think I didn't log the February one, but had info from January and before, and it's all gone. Also, I usually log some other symptoms, like tender breasts, and can't find any of those.
Thank you.
04-19-2020 15:55
04-19-2020 15:55
Welcome to the Fitbit Community, @JoMatos. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing that your logged information before March has disappeared in the Female Health Tracking feature. Thank you for providing the additional details, I am glad to help you with that.
I recommend to log out of the app, restart your phone and then log back in. Please also make sure that your Fitbit app is updated to the latest version: How do I update the Fitbit app?
For more information about the female health tracking feature, see this help article: How do I use the Fitbit app to track my period?
Keep me posted on the outcome.
04-21-2020 01:02
04-21-2020 01:02
Thank you for your reply.
I did what you suggested and the logged info didn't come back. Still only shows from march on.
04-22-2020 14:54
04-22-2020 14:54
Hi @JoMatos, thank you for your reply.
I appreciate your efforts and the additional details. Please let me know what device do you use to check your Fitbit app information and the operating system. I'll be glad to investigate further.
Looking forward to your response.
04-23-2020 11:15
04-23-2020 11:15
Hi!
I have a Mi 8 Lite with miui 11, Android 10.
Thank you
04-27-2020 15:53 - edited 04-29-2020 17:52
Thank you for providing the additional details, @JoMatos. I am sorry for the delayed response.
While your phone is not supported by the Fitbit app at the moment and some of the functions might work intermittently, I recommend following these steps. Note you’ll need to log back into the Fitbit app with your email address and password.
Let me know how it goes.
04-28-2020 06:23
04-28-2020 06:23
Hi! Thank you for your reply.
I didn't try the steps as the missing info was all in place when I checked today. So, it is solved... I had logged off and on, and reconnected the watch in the process, a few days ago because of other bug and maybe that was what solved it? I don't know, but everything is its place now.
Thank you so much!
04-29-2020 13:49
04-29-2020 13:49
I am glad to hear the issue is resolved now. Thank you for sharing the additional details, I appreciate your time and feedback and hope you continue enjoying the Fitbit experience.
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Keep on visiting the forums! Let me know if you have any questions.
04-29-2020 14:15
04-29-2020 14:15
I just have to say that fitbit is for the most part fantastic and so is the app. But the period tracker is garbage. And it almost seems like you guys dot all your I's and cross all your t's when it comes to the entire app EXCEPT the period tracker. It's like you guys don't even check if your updates cause malfunction in the period tracker. I really don't understand because on one hand everything else works flawlessly, on the other it's like fitbit doesn't even bother testing the period tracker before putting out updates. It boggles my mind. How can you guys do such a great job and then be so completely careless?
The period tracker has never worked properly for more than a few weeks at a time. I have gone through troubles logging my period, adjusting the start and end dates, info spontaneously deleting, info not saving, periods randomly changing to different predicted dates, past periods randomly changing to different dates etc etc etc. Each time I visit these forums where hundreds of others are complaining about the same things. I get the fix and a couple weeks later there's a new problem.
Just remove the female health tracker if you guys aren't serious about it. It's very obvious that it's not a priority to have it work properly and it's not cool to keep telling people it's fixed when it's going to be broken a couple weeks later, compromising important data we are recording. I will not be using it anymore. This is the last straw. For the past month it hasn't been saving my details when I thought it was. I go back and look at my other period details and there's random details that have been saved that I never put there! I just followed the fix in the above instructions and now ALL of my details have been deleted. Thanks.
