05-30-2018 07:00
05-30-2018 07:00
I entered the wrong date of my last period when i first set up female health tracker, now i dont know how to re set it so i can re enter the date. Any ideas please?
05-30-2018 14:09
05-30-2018 14:09
Hi, @Shanae98, just go to the incorrect data you have entered and delete it. Then sync your Fitbit, and everything will be gone. Then you can start again.
Technically you don't need to delete, sync and then add again. You can just edit and re-add and then sync. But you can sync just to make sure everything is up to date if that gives you more confidence. (I am a step by step sort of person myself... so I like to make sure everything is gone before I start again.)
