03-01-2020
11:18
06:38
YojanaFitbit
03-01-2020
11:18
06:38
YojanaFitbit
is there a way to indicate if the period was late
03-02-2020 06:37
03-02-2020 06:37
Hello there @notworking, welcome to the Community Forums. I'll be more than glad to help you out with your inquiry.
First of all, I'd like to mention that during your predicted period, you’re asked to confirm whether your period started. Tap or click Yes to confirm that your period started or Not Yet if it hasn’t started. Tap or click Edit to adjust the dates before you confirm your period.
If you confirm a predicted period, the predicted period becomes a confirmed period. If you don’t confirm a predicted period, the prediction remains on your calendar. After the last day of the prediction window passes, the entire predicted period shifts to the next day. Note that the calendar doesn’t update until after midnight. Initially, your predictions take into account the average cycle and period lengths you provide during setup. Log your period consistently to receive more accurate predictions.
Your estimated fertile window automatically adjusts based on the menstrual cycle data you enter. You can’t edit fertile windows at this time. You can swipe down to look for the date you want to edit and follow the steps below.
To add or edit a period:
To delete a period:
If you have trouble adding or editing a period, see our troubleshooting tips.
04-14-2020 08:25
04-14-2020 08:25
I do not have the delete option when I click on the pencil icon. I only see save or cancel.
