12-02-2019
14:25
11:58
YojanaFitbit
12-02-2019
14:25
11:58
YojanaFitbit
This module doesn't work, unless working for 26 days of a cycle and then resetting itself is considered working. When are you boy programmers gonna get you stuff together and stabilize the product, or remove it. I have to use a different software's to monitor female health because the one on the most expensive Fitbit watch sold will not work consistently for even a month. My cycle does not begin on the 1st of the month, but my periods begin about the 20th, and its a consistent 28 day period, with ovulation occuring on the 15th day, But every month around the 6th of the month, fitbit resets the counter, and suddenly my period began around the 27th and I have to reset it. This has happened every month since the Female health module was released. Get it together guys, or remove it from your watches, and let us get something that works month after month.
12-03-2019 11:57
12-03-2019 11:57
Hi @Baatkinson98 nice to see you around. Thanks for sharing your feedback about the Female Health tile. Sorry to hear that you've had issues with your previous periods. I'll be glad to give you a hand with this.
Fitbit uses the data you provide to estimate your predictions. Initially, your predictions take into account the average cycle and period lengths you provide during setup. Log your period consistently to receive more accurate predictions. Can you please confirm how many times you've enter or confirmed your previous periods?
During your predicted period, you’re asked to confirm whether your period started. Tap Yes to confirm that your period started or Not Yet if it hasn’t started. Tap Edit to adjust the dates before you confirm your period.
If you confirm a predicted period, the predicted period becomes a confirmed period. If you don’t confirm a predicted period, the prediction remains on your calendar. After the last day of the prediction window passes, the entire predicted period shifts to the next day. Note that the calendar doesn’t update until after midnight.
To add or edit a period:
To delete a period:
If you have trouble adding or editing a period, see our troubleshooting tips.
Please keep me posted, your comments are very important for us.
