08-14-2019
11:00
12:07
08-14-2019
11:00
12:07
I have my cycle set to 28 days. However, on the tracker calendar, it set itself to 119 days and I can’t seem to fix it. I’ve updated the app, uninstalled and reinstalled it, editing previous periods to the right dates, etc.
I’m struggling here and would love for it to work right so I can make sure I’m not on my period for my wedding or trips (without having to count it out myself).
Moderator edit: updated subject for clarity & added label
02-03-2022 08:27
02-03-2022 08:27
Okay, y'all, since everyone is still having troubles with this, I thought I'd pop on to tell you what worked for me.
So, basically, the app defaults to an average of ALL your logged periods for your cycle length. So I noticed that I had some periods that I logged from maybe a year or so ago, then I missed logging for a few months, then I started logging again once Fitbit became my dedicated period tracking app. What happened, however, is that the default Fitbit algorithm used the average of all those missed periods saying my cycle length was 428 days. So I deleted all the old period data from when I wasn't consistently tracking, and it immediately solved the problem.
So, if you notice your app data isn't correct, you might need to go through and delete old periods or add periods that you missed tracking so that the app will then show closer to what your default cycle length is. This immediately solved my problem. I hope this is helpful!
02-15-2022 09:42
02-15-2022 09:42
This worked for me thank you!!!
10-12-2022 07:15
10-12-2022 07:15
This has been driving me nuts for the past week! You’re a sanity saver! Thank you!
02-19-2023 12:38
02-19-2023 12:38
That finally worked. Thank you! But we shouldn't have to delete all our data to edit the cycle length.
