09-20-2018
23:41
05:31
09-20-2018
23:41
05:31
My period/fertile days predictions have been the same for a month (since my last period). I haven't changed any info, but when I woke up this morning, all of the dates have changed.
I'm just wondering why this has happened?
I've force quit the app, turned predictions off and on again, but they have not changed back to what they were before.
Welcome on board @Lauriegoldie, it's nice to have you here! Thanks for taking the time to troubleshoot this inconvenience, nice way to go!
I'd recommend doing the following:
Give this a shot and let me know the outcome! ![]()
I pretty much have had this problem since the Woman’s health was added. My period was changed by the app at least 4 times. Really annoying. And nothing seems to stop it. This morning I woke up and it moved again without changing anything.
Thanks for reporting this girls @Lauriegoldie and @Alissa91! Also, thanks for the steps you've taken in order to sort this out.
Please go to Settings in the top right corner. It should bring up the option to remove "predictions". Tur it off, set your period then turn predictions back on.
Let me know if this bring your periods back!
Glad to hear they are back @Lauriegoldie! This is the first time I read something like this happens. The dates cannot change by themselves unless we manually edit the periods. However, this is not the case as you mentioned at the very beginning you didn't change anything.
So, I'd appreciate if you keep testing your app and see if this happens again so I can go from there.
In the meantime, I'd recommend taking a look at: How do I use the Fitbit app to track my period?
I'll be around if you need further assistance. Have a nice day!
Hi all,
My Fitbit has just started acting up in the same way. On both cases the logged dates changed overnight. As far as I can tell they 'stay put' once I have manually changed them back, but it's quite bizarre (and annoying).
I will give disabling the predictions a go, if you think that might help,
Hi there @Marieluise, it's nice to see you around here! Please try following @Lauriegoldie's suggestion and see if that helps to you too. ![]()
In addition, I'd recommend taking a look at: How do I use the Fitbit app to track my period?
Let us know how it goes!
Welcome on board @Mbekstein, it's nice to see a new member here! Thanks for uninstalling and reinstalling the Fitbit app.
Please try going to Settings in the top right corner. It should bring up the option to remove "predictions". Turn it off, set cycle length again then turn predictions back on.
You can edit the average cycle length and period length you provided during setup; however, these settings only affect your initial predictions.
Keep the following in mind:
To change your setup values for average cycle or period length:
Give this a go and let me know how it goes.
Hello there @Mbekstein, thanks for coming back and for letting me know you've tried the steps recommended.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Please let me know if there's anything else I may do to assist in the meantime.
I am having the same issues. I have tried all the steps listed above but my Fitbit app has done this to me at least the last 4 times. The first time I thought maybe I had done something but last night was the last day of my period, my Fitbit knew it, and when I woke up this morning it completely changed to tell me today was the first day after I already acknowledged the first day went it did it originally last week. I would love for you to add my name to this issue because clearly this is a bug with the app since so many are having this issue.
Welcome on board @Laurah91, it's nice to see you around! We appreciate your time and patience regarding this matter.
Since this situation turned out to be uncommon, we need to research the root cause of the issue. This, as you may know, takes almost the same amount of time that it takes for us to release any new feature/update from the previous platforms that we have launched already.
We can't determine any specific date to provide to you. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
If you have any questions, don't hesitate to let me know.
Best AnswerI'm not sure how you can say that this is uncommon... In the last month you've had at least 4 others with this problem plus it looks like the original post started in 2018. Most don't think to post on the FitBit community area. This has been going on for months for me but I didn't think to post until yesterday. So the idea that this is uncommon seems a little shortsighted. I appreciate that it takes time to research issues and roll out a patch for a bug and it may not happen until the next software update. I do hope Fitbit works to fix this ASAP as it would show me that they actually care about their customers and value the experiences and opinions of their female customers especially who, at the moment, seem to be the ones being forgotten.
Hello @Laurah91 and @Mbekstein! I am sorry to hear that you are going through this situation too. I'll make sure to keep you all posted as soon as the are updates available.
Let me know if there's anything else I may do to assist you in the meantime.
Best AnswerThis happens to me almost monthly. It will be right on and then all of a sudden two weeks later when my period is supposed to start has jumped. I haven’t touched any of the settings. I keep my Fitbit app up to date and I keep it synced with my Versa. Why does this keep happening?
