01-25-2024 04:54 - edited 01-25-2024 04:57
I have read many complaints and concerns related to the HRV values given by Fitbit devices. In the sense that they appear too low for what one would expect or much lower than values given by other measurements. Which made a lot of people worried about their health condition or simply discard Fitbit values as nonsense.
I am not an expert on this field or anything like that, but these are a few pieces of information I gathered about this issue since I was also wondering about it.
On the Google Fitbit Help Center website as well as within the Fitbit app one can read the following:
'Fitbit uses the common formula called RMSSD to determine HRV from your recent heart-rate data.'
Based on other sources, it appears that there are many methods to calculate and analyze HRV, including RMSSD. So, what Google states in the above quote seems to make sense. They are calculating the HRV based on one of the formulas available for this purpose.
Further, there seems to be two main formulas used to calculate HRV, and again, one is the RMSSD used by Fitbit and the other is called SDNN. The main thing is that these two formulas produce different values for the same condition. So, if you use a measurement based on the SDNN formula, the results will be higher than those measurements relying on the RMSSD formula.
The RMSS formula is quoted to be a standard statistical measure of HRV and it basically refers to Root Means Square of Successive Differences, therefore RMSSD. It measures the time difference between each successive heartbeat in real-time to arrive at your RMSSD score. This formula seems to be helpful for investigating the impact of training loads and recovery processes.
And now the most important part.
It seems like based on the review of different studies related to normal values for short-term heart rate variability in healthy adults, the following HRV values are supposed to be normal:
Measurements based on SDNN (ms) 32–93
Measurements based on RMSSD (ms) 19–75 (what Fitbit uses)
To put all this into some perspective. In my case, based on the SDNN formula, I am getting values from 40 to 66 ms. My HRV scores on Fitbit are between 30 and 39 ms, which indeed fits under the RMSSD formula values above.
I hope this helps.
01-26-2024 12:09
01-26-2024 12:09
Hello @SunsetRunner
Thank you for taking the time to explain how Fitbit calculates HRV as well as the normal range. This will be very helpful for those concerned with their Fitibit HRV data.
06-18-2024 09:39
06-18-2024 09:39
Thar is exactly what I discovered when becoming concerned that my hrv ranged between 28 and 42. I am 67 and when I googled healthy hrv I saw results that showed I was in poor condition. But when I researched further I found there are many ways that hrv are measured. Like Celsius and Fahrenheit for temperature. The range I am in is actually very good for my age. Fitbit ought to have a better explanation on their page about hrv and which method they use!
06-18-2024 15:38 - edited 06-18-2024 15:38
For anyone interested in seeing how their Fitbit HRV score compares, this chart will be helpful
07-31-2024 03:43
07-31-2024 03:43
Thanks for the explanation and chart. I suspect that the HRV is just inaccurate. Many people complain that theirs is too low, but mine is consistently too high. I have an average of 75 taken over years and over 100 in the past month with several readings over 140 this month. I am a 54 y.o. male. This would put my average over 2 SD above the mean and 3-4 SDs over the mean for the month and 5 SDs over the mean for my high readings. I exercise, but I'm not any kind of elite athlete and as far as I know I don't have any weird medical conditions. I have had two fitbits over this time and both have similarly given me high values.
01-18-2025 04:40
01-18-2025 04:40
My HRV is showing as 20 to 9 is the lower end a problem for a 65 year old male?
01-21-2025 09:15
01-21-2025 09:15
Ways to improve your hrv: cardiovascular exercise, meditation, yoga, diaphragmatic breathing, to name a few. Best of luck to everyone working towards a healthy heart!
02-06-2025 06:48
02-06-2025 06:48
i am a jogger in mid 60s and topping out at HRV of 12!
I opened a ticket w google back in mid december and they were unable to help me. i chatted w them over a week ago and they said they would re-evaluate my OPEN case. Still havent heard from them!!!!
