11-14-2017 06:36
11-14-2017 06:36
Do any of the other ladies notice a trend between resting heart rate and the monthly cycle?? This is my 3 month track of heart rate and shows massive changes depending on where I am in the month! Is this
normal?
12-24-2018 18:12
12-24-2018 18:12
Me too, but I thought it dropped because of the painkillers I took.
01-27-2019 05:44
01-27-2019 05:44
Yep I have almost exactlyethe samesxactly but no endometriosis
02-12-2019 15:38
02-12-2019 15:38
Yes i agree, ive noticed mine increases the week before im due and gets to its highest point then when i start bleeding it starts dropping to its lowest... ive also noticed it jumps up a few before ovulation and drops slightly again... and i have aligned this info with my other period tracker apps for the ovulation/cycle times and they match up almost spot on everytime.
03-09-2019 07:48 - edited 03-09-2019 07:50
Can't figure out how to share a pic. But mine is exactly the same!
03-29-2019 02:34
03-29-2019 02:34
I'm glad to hear it's not just me. I recently started fertility treatment and my average resting bmp skyrocketed from 60 to 66. I see it when I sit down behind the PC, normally it would go down and now it stays at 70 bpm... I really hope this changes when I finish my dosage, because it's messing with my head! 🙂
03-29-2019 17:12
03-29-2019 17:12
03-29-2019 18:04
03-29-2019 18:04
04-17-2019 08:23
04-17-2019 08:23
So mine usually does this but for some reasone this month it has held almost consistantly at 70 all month. Im on cycle day 22. Does anyone know why it nevered changed? We are trying for baby #2 and I'm worried i didn't ovulate this month because my heart rate never went up.
05-07-2019 05:19
05-07-2019 05:19
Hi Jess,
I was thinking of replying to you but waited for the end of my cycle to check my own results.
I'm not sure if the heart rate builds up before the period or during the ovulation. For me it does after I ovulate but before my period. At the same time, I recently discovered I have PCOS so I probably don't ovulate at all (now undergoing fertility treatment).
I hope you learn soon that you're pregnant! And keep your fingers crossed, because I'm trying for baby no1! 🙂
05-07-2019 05:55
05-07-2019 05:55
Hey!
Yes Im pretty sure i didn't ovulate... i ended up starting my period but it was late... 😞 Heres hoping for better luck this month. Keeping my fingers crossed for you!!
05-07-2019 07:12
05-07-2019 07:12
In 3 month view, HR should spike in luteal phase (before period) and dip in follicular phase (after period) and during ovulation I can sometimes see a tiny spike of 1-2 BPM for 1 day (in 1 week view) during the incline from low to peak . however there are so many factors affecting a woman's body so even though that's fairly regular I screenshot a strange "flat" time for me too. Maybe stress or meds or anything!
05-07-2019 07:45
05-07-2019 07:45
Thanks for replying! Yes idk what was up with the flat month haha. I guess i know to watch for that now.
05-10-2019 12:15
05-10-2019 12:15
I have the same pattern! Glad I came across this posting.
06-03-2019 14:04
06-03-2019 14:04
I was searching around the internet trying to work out my heart rate pattern and came across this thread. The RHR pattern is very interesting. Mine is below. I am on the pill and regularly run packs together to skip periods. The first dip is a normal period. The middle small dip is when I should have had a period. The final dip that I am still in is my current period.
06-05-2019 16:03
06-05-2019 16:03
Either you have it backwards or my body has it backwards because I spoke at ovulation and hit my lowest just before my period starts.
06-21-2019 09:11
06-21-2019 09:11
Yes! I’ve googled it and evidently it’s scientific and **ahem**. 😂
07-28-2019 04:23
07-28-2019 04:23
Hi,
Are the numbers you quote your resting heart rate?
So 78 resting heart rate at highest and 65 resting heart rate at lowest?
thank you
07-28-2019 05:19
07-28-2019 05:19
Hi. Yes it's resting but highest is around 71 and lowest around 65
07-28-2019 06:37
07-28-2019 06:37
07-28-2019 07:32
07-28-2019 07:32
My RHR is 68 at highest and 63 at the very lowest.
I'm 41, 10stone, reasonably healthy and don’t drink caffeine or smoke but my heart is so erratic! I suffer pretty much constant pain but worse on my period. Currently being investigated for endo.
