03-28-2021 14:49
03-28-2021 14:49
My app is up-to-date, but lately every few days it won't sync. Today I can't get yesterday or today's step counts on the app, but I know the Fitbit counted yesterday's, and has counted today's so far. The app indicates my battery is low but when I put it in the charger it shows full. I tried uninstalling and reinstalling the app, restarting the tablet, logging out and logging back in. I am stumped.
03-30-2021 09:03
03-30-2021 09:03
@Barb612 @SunsetRunner likely nothing to do with the app or tablet. It sounds like your battery is dead or dying. Unfortunately, this happens as they're only rated for a couple of years. If showing full on the charger but nothing when disconnected, it's dead. If showing full-on charger but low battery when disconnected, it's dying and/or not charging properly.
03-30-2021 08:49
03-30-2021 08:49
Listening same issue with mine.
03-30-2021 09:03
03-30-2021 09:03
03-30-2021 13:15
03-30-2021 13:15
The app will only report the battery level at the time of the previous sync. If the tracker hasn't synced in a few days, yes the level reported in the app will not be correct.
See here for help with syncing.
04-01-2021 08:40
04-01-2021 08:40
I was afraid it had to do with the age of my One, which I started using 6 years ago, and you've confirmed my fear. Guess it's time for another option for the long haul.
04-01-2021 11:27
04-01-2021 11:27
@Barb612 there is a thread on changing the battery on the One. This normally is tge failure point.
I'm sure you know someone who could do this.
04-01-2021 12:58
04-01-2021 12:58
@Barb612 6 years is an amazing value from this little tracker. You can try replacing your own battery or buy a new One with a new battery or a good condition used One on eBay inexpensively right now.
@SunsetRunner see the links above in case they may help you and visit the thread here on how to replace the battery. Feel free to ask any questions, I've successfully recovered several Fitbit Ones. Cheers!
04-09-2021 14:09
04-09-2021 14:09
I'm having the same problem as you.
