02-16-2016 15:25
02-16-2016 15:25
Best Answer02-17-2016 03:22
02-17-2016 03:22
Welcome to the Community @scottishagate. If you want to change your water unit, do the following from a computer:
1. Go to Settings
2. Go to Personal Info
3. Go to Unit
4. Change your unit
5. Sync
You can also check the attached image.
Let me know if you need further assistance. ![]()
Best Answer02-17-2016 04:10
02-17-2016 04:10
Thanks. I didn't make myself clear, my Water Units are already set at millileters. But the numbers are given in two decimal points, are they converted from another country's system?
At present, the "glass" is rated at 236.59ml Adding more glasses gives 473.18 ... 709.77 ... 946.39. Not quick to comprehend at a glass.
So can I change the value of the glass to 250ml, so I get 250 ... 500 ... 750 ... 1,000 etc.
