10-21-2020 05:44
10-21-2020 05:44
Hey guys. I think I’m sol. But my fitbut one won’t sync. I’ve tried the blue tooth thing. My app and one are up to date. But I can’t reset it anymore. The button on it isn’t responsive. 😕 I’ve tried the new wrist ones but can’t wear them with my job. I really need it fixed 😭 and I can’t get this one anymore. Anyone have any other suggestions. It quit syncing 12 hours ago and just stopped.
10-21-2020 06:04
10-21-2020 06:04
Mine quit syncing, too, about 24 hours ago. Wonder if it's a system problem?
10-21-2020 06:15
10-21-2020 06:15
I really hope so. I love my Fitbit one and don’t want to give it up
10-21-2020 06:47
10-21-2020 06:47
I am having the same issue!
Mine stopped syncing early yesterday. I would be sad to lose my steps from the last couple days also!
10-21-2020 06:56
10-21-2020 06:56
I am having the same problem! How do we get a resolution from Fitbit?
10-21-2020 07:02
10-21-2020 07:02
mine has also stopped syncing since 17th Oct 2020. very frustrating as l can wear wrist one either.
10-21-2020 07:16
10-21-2020 07:16
Good day,
Mine also stopped synching about two days ago. From the app I removed and re-added the device (in the iphone app) and it is synching again. Maybe that will work for you too?
Take care!
10-21-2020 07:16
10-21-2020 08:51
10-21-2020 08:51
Thank you bobertbeen. I had the exact same problem and your solution was so helpful........ It worked for me as well. Thanks again
10-21-2020 09:03
10-21-2020 09:03
Mine quit thinking too. The app says it can’t find it. I love my Fitbit one! It’s the best thing ever! How do we get help from this company?
10-21-2020 09:11
10-21-2020 09:11
I just rebooted my One and it's now syncing again including the prior days' steps, etc.
10-21-2020 09:14
10-21-2020 09:14
I can’t reset it my button is quirky
10-21-2020 09:14
10-21-2020 10:47
10-21-2020 10:47
Hi bobertbeen. Same issue till yesterday. Your solution worked for mee too. Many thanks.
10-21-2020 10:55
10-21-2020 10:55
I just tried that and still not working. Thanks for the suggestion.
Best Answer10-21-2020 11:18
10-21-2020 11:18
Same here. Cannot sync to iPhone. I’ve also tried all of the “solutions”.
Best Answer10-21-2020 11:43
10-21-2020 11:43
Thanks! Before removing and adding it back to the app, I tried a second time to restart it while in the charging cable. That worked!
Best Answer10-21-2020 13:31
10-21-2020 13:31
I just purchased an Inspire. You can buy a clip for it and not wear it as a wrist device. I'm still using my One. But it quit syncing yesterday. I've done a reset and nothing. ☹️
Best Answer10-21-2020 13:40
10-21-2020 13:40
I "rebooted" 3 different times (didn't work), then uninstalled the fitbit app, reinstalled the app, "rebooted" again, and it worked!
Best Answer10-21-2020 15:13
10-21-2020 15:13
I'm just trying to sync down to my computer and it doesn't work, and it also is keeping the wrong time
