07-28-2016 13:30
07-28-2016 13:30
I am on my 4th fitbit one in 2 years. After about 9 months the battery just craps out without warning. one day it's fine and the next it won't hold a charge for more than 2 hours. The first 2 were replaced by fitbit, but this last time I didn't bother going through the process because it took like 6 weeks, and I didn't want to be without my fitbit for that long. It seems crazy that these devices are so "disposable". Is there a way to make them with better battieries or at least make the batteries replaceable? Seems like a huge waste.
Best Answer07-28-2016 13:53
07-28-2016 13:53
Are you charging it on your computer with the USB Port as that is the best way.
I have had mine for 3 years and it stills hold a charge for 9 days.
Wendy | CA | Moto G6 Android
07-28-2016 17:31
07-28-2016 17:31
Welcome to the community!
I have had a similar experience to @WendyB. I have had my Fitbit One since 07/24/2013 (looked up my order on Amazon) and mine lasted 9 days between my last two charges (07/14 to 07/23, since I keep the notification emails).
I'm wondering if you're not charging fully or if something is draining your battery quickly. Let us know if you want us to help you diagnose.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
07-29-2016 14:00
07-29-2016 14:00
Best Answer07-29-2016 17:15
07-29-2016 17:15
No you do not need to send it in. But you should of contacted support they would of offer you a discount.
But you never answered how you are charging it. Computer is best with the charger plugged into the USB port
Also I always charge mine at night but computers do go into sleep mode and if that happens it might not be charging fully. Do you check after charging to see if its full?
Let us know how you are charging it so than maybe we can prevent it from happening to the new one.
Best Answer07-29-2016 17:50
07-29-2016 17:50
Best Answer07-29-2016 18:17
07-29-2016 18:17
Best Answer07-30-2016 05:58
07-30-2016 05:58
this is happening to mine as well.. mid-day the battery dies ( no steps are logged). I reset the fitbit and plugged it into my computer to charge.. and it says that the battery is fully charged!! ANY IDEAS??
